Question about Beko Televison & Video
How to use setup box in beko tv - Beko Televison & Video
Hi i need the code for my beko tv
0039,0036,0031. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 21, 2014 | Beko 324250WN 28" TV
Tv channels setup
Sounds like its main system control memory IC is faulty. Contact and service technician to confirm it and to replace. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Beko Televison & Video
Looking for code for innovage jumbo remote control to work on a beko tv
028,026,002,018,074. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 18, 2013 | Innovage Jumbo Remote Control
I need a remote code for a beko tv using a
For more details, type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:- Setup codes and setup proceedings are given in detail. You can see setup codes for almost all TVs here.
Jun 03, 2012 | Televison & Video
Hi there! I have a 19" Beko Tv about 4 years old. The sound has gone altogether. Picture good though. We have it attached to a freeview top box. Husband saying its the topbox that's faulty. ...
I assume that you have attached it via SCART cable...since SCART plugs have 21 pins, and carry video, audio and switching signals ,sometimes a bad connection on either TV side or Top Box side ,the sound goes off first..Make sure your SCART plugs securely fit to either side.
If it does not help pls visit the URL below for further advise before going to blame the Top Box....
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Set-top Box Connection Advisor This page is designed to help you with connecting your Freeview, BT Vision, Virgin Cable, Freesat or Sky satellite set-top box to your home TV system. http://www.radioandtelly.co.uk/connecthelp.php
Feb 02, 2011 | Beko 324250WN 28" TV
Sky codes for beko 32' tv
on the sky remote press the following
TV
RED + SELECT (blinks twice)
TV
0125
press the volume button,if it works press SELECT if not press TV then VOLUME again repeat this process of TV then VOLUME until it works then press the SELECT button to save the code to your remote.
Enjoy
Littlle Dish Fitter
Dec 27, 2008 | Beko 324250WN 28" TV
Beko 28c723idw has lost all digital channels
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Nov 23, 2008 | Beko 324250WN 28" TV
NO PICTURE JUST A HORIBLE CLICK/WHINE
Hi,possibly the line output transister has gone short,proberbly caused by a dry joint,or worst case it is the line out put transformer itself and that could be a bit pricey to replace.
Apr 15, 2008 | Beko 324250WN 28" TV
Tv is stuck on av channel
no-not the tv try buying another remote from the manufacturer and that will solve the problem
Jan 06, 2007 | Grundig GF70-600 TV
Televison & Video Logo
26 people viewed this question
Top Beko Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Beko Televison and Video Expert? Answer questions, earn points and help others
