Question about Crafts & Hobbies
Change colors for down loaded images om cricut explorer
What will I need to buy to start using my Cricut explore air making t-shirts mainly
How to Make a Custom Shirt with Your Cricut - Pretty Providencehttps://prettyprovidence.com/make-custom-shirt-cricut/Proxy Highlight
Jun 27, 2017 ... You can make custom DIY t-shirts so inexpensive when you use your cutting machine. ... If you're like me, you have a lot of inside jokes with family or friends and love custom shirts. I have spent SO ... I am just popping over here to share my Cricut expertise but typically blog at Practical and Pretty! I'm so ...
Nov 30, 2017 | Crafts & Hobbies
Will cricut explorer one run on a dual core computer
Ask the maker.... "Contact us" on the website:
https://shop.cricut.com/en_ca/machines/cricut-explore-air.html
"Contact us" is way down on the bottom in the small print. Good luck.
May 23, 2017 | Core Computers & Internet
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    Cricut explore one. Downloaded program,but get error message,wont install
    Frustrated!!! [Driver installation problems][Resolved] - Make The ...
    forum.make-the-cut.com/.../frustrated-driver-installation-problems-resol...
    May 11, 2010 - 29 posts - ‎10 authors
    I cannot get the Cricut firmaware to update. ... I just got a new computer with Windows 7, I tried to cut with the cricut but I get two error messages. RESOLVED Problem getting computer to recognize Cricut
    Dec 15, 2010
    RESOLVED!!!Help Sending Cuts to Cricut
    Jul 24, 2010
    Cricut Error: Unable to load drivers
    Jan 28, 2010
    cannot get program to cut
    Jan 14, 2010
    More results from forum.make-the-cut.com
    Dec 28, 2015 | Computers & Internet
    How do I use the Artbooking cartridge on the cricut design studio?
    Cricut design studio is no longer supported by Cricut but if you mean Cricut Design Space then this is how you do it. Open and sign in to Design Space select insert images and in the box on the right select my Image sets and then type in Artbooking. Artbooking cartridge will then come up for you to select what you want. all images come onto the mat at 2.5 inches they havent fixed this yet so you have to resize your images. If you want to download the image numbers from the artbooking book which go with design space go to http://thenon-craftycrafter.blogspot.co.nz/p/image-codes.html and download the artbooking book from this lady please join her blog and leave her a message as she does a lot of work all of which she does for free. Also if you youtube cricut design space. or go onto design space in cricut.com
    Aug 20, 2014 | Cricut Expression Cutting Machine
    Cricut expressions 2 pressure wheel
    You say you have a Cricut expression 2 but you say quote"...of how to reset the machine including the rolling of the dials up and down three times!" The problem I have in sorting your problem is that the Cricut expression 2 does not have wheels which work the speed, pressure and size. If you have an expression version 1 machine then there would be 3 wheels on it to adjust the speed pressure and size. Obviously if you have had the machine for 4 years it is out of warranty and I am not sure just what the person did to "fix" your problem. I do recollect a video on you tube with a similar problem however looking at the video he mentions that once it is fixed the blade housing should bounce up if you push it down, does your housing now do the same as the video. In the video Evan did he mentions at the end that the soldering of these wires may not take the first time so this may be a point to check as he mentions that it was travelling the machine that caused the wires to break in the first place. The youtube.com video I am speaking of is http://youtu.be/n7LJnfPdd08, by Evan Craftman. I am assuming that when you called cricut support you called the UK support line. I often speak with support in the USA being from New Zealand it is an overseas call however I have found them very good. If you are able to I would like to see a video of just what your machine is doing. If you dont want to post it here you could email me flohillrennie@gmail.com.
    I do feel very sad that you don't wish to try the Explore as I find it a surpurb machine. I have had my Expression version 1 since early 2009, I have added every Cricut to my family of cricuts and own 3 expression 2's and now an explore. If you had bought a computer 4 years ago and you currently took it to a repair person to get it fixed I am sure their first response would be it would be better to get a new one. Your computer boards appear to be fine maybe you need to take the video to the person who did your fixing as most people who do this sort of work would not understand how the machine runs. I hope this helps and you can get your Cricut working again. If all else fails you may be able to buy a 2nd hand one cheep and have your repair person change the carriages completly.
    Jun 13, 2014 | Cricut Expression Cutting Machine
    My Cricut Expression is not working. When i pressed the cut point on the screen all it did was a loading screen and would not cut. What should i do?
    fruchey10 you have not given me enough info to help you but if you contact me I will try to work out a solution to your problem. exactly what are you doing ie do you have images loaded onto the image queue. contact me via my website OhSoManyCrafts
    Feb 02, 2014 | Cricut Expression Cutting Machine
    Jpeg file onto a cricut
    Cricut does not accept jpegs. They use their cartridges that come with the machine and others that you can purchase. However if you have Cricut Design Studio you can design your image with the cricut. Any further questions feel free to ask.
    Dec 02, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut Expressions Machine error
    1. Make sure your cricut is off when you plug it into your computer via usb.
    2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
    3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
    4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
    5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
    6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
    Hope this helps you.
    Jun 10, 2009 | Provo Craft Cricut Disney Font Cartridge
    Crafts & Hobbies Logo
    755 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
