Question about Kitchen Ranges
Clock shows 5Ab. Can not get this cleared off clock. Hit cancel many times. Need to bake and cannot put temp on.
    Sergeant:
  • 163 Answers
Hi Susie
http://www.samsung.com/ca/support/skp/faq/1059001
This will help
Sir John Dana Hamilton Taylor
Posted on Apr 24, 2017
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
The actual temperature of my oven does not agree with what it says on the digital readout in the clock area. I have been told that you can adjust the reading of the clock, but I cannot find the service...
Press bake and set temp. to highest setting on some it's 500 on others it's 550 aftef setting to highest bake setting. Press and hold bake button until 00 is displayed,use up/down arrows to adjust in 5 degree incriments to plus/minus 35 dergees . ONce you've adjusted it push cancel/off button and you adjustment will be stored even if power loss and clock went out.
If your temp is more than 35 degrees off the clock needs to be replaced
Aug 16, 2011 | Ovens
The electronic panel related to oven and clock does not work. code 5ab appears on the display
Hello, welcome to FixYa.
Your range has somehow been set in "sabbath" mode ( for the Jewish calendar I think...not the metal band, lol ) If you have the owners manual turn to the section referring to this an it should instruct how to reverse the setting.
All ranges do it somewhat differently, so I can't say exactly how on yours. This example is generic, hopefully it works. If you are unsuccessful let me know the exact model number and I'll see if I can locate it.
Hold Clock pad for 5 seconds to activate Sabbath mode. Hold Clock pad for 5 seconds to disable Sabbath mode.
Oven must be in BAKE mode before enabling SABBATH. "SAb" displays and flashes for 5 seconds. All pad inputs are disabled except for CANCEL and CLOCK pads.
This mode disables the normal 12 hour shutoff to allow operation of the bake mode for a maximum of 72 hours.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 18, 2011 | Maytag Gemini 30" Self-Cleaning...
Screen fixed showing 5Ab
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models, you simply press and hold the "Clock" button for 5 seconds. On other models, you press and hold the "Stop/Time" and "Cancel" buttons down at the same time for 3 seconds. These instructions should be in your owner's manual.
If these instructions do not work for you, or if your model number is different than what you posted this question under, please post back with your correct information so that I may be able to assist you further. I hope this helps you.
Nov 15, 2009 | Maytag MGR5750 Gas Kitchen Range
F0 fault code
Hi ,
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
May 29, 2009 | Jenn-Air Ovens
Change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Phil
Apr 10, 2009 | Maytag MER5775Q Electric Kitchen Range
My gas range display changed to "5Ab" and does not work anymore.
You are set to Sabbath mode.
Try holding the clock button in for 5 seconds and that may correct it.
Mar 10, 2009 | Amana RanARG7302 Gas Kitchen Range
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
