What does it mean rt2 - Computers & Internet
Yamaha RT360 point gap
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tune Up Quick Reference 250 360 400 models
How to adjust the timing points on Vintage Yamaha 2 stroke or almost...
1970 1971 RT1 360cc DT2 RT2 Yamaha Motorcycle Service Manual $25
Yamaha Rt2 1972 Usa parts lists
http://mybikemanuals.com/yamaha/yamaha-rt-owners-manuals
Jun 15, 2012 | 1974 Yamaha DT 360
1972 Yamaha RT2MX (360cc) stator assembly has been removed from the engine, and I need to know how to install it correctly, so the CDI will fire the spark plug at the correct point of crankshaft...
My manual for the rt2 360, shows points, perhaps someone has fitted a later model ignition. and flywheel
This may mean trial and error, see if you can see where the screws used to mount on the slots, or try it half way, then if it will start, use a auto timing light to see how close it is to firing on the F mark.
If it is not the original flywheel, check that when the piston is at the top( TDC), the timing mark points to the T mark
Jul 06, 2011 | 1972 Yamaha DT 360
Radio meter wont move
adjust RT2 to see if meter will move then.
Dec 03, 2010 | Radio Shack TRC-447 CB Radio
I want drive for dvraptor rt2 please
i want to get driver Canopus Dvraptor for set up my Canopus Card.i am a Video Designer
Aug 09, 2010 | Canopus DVRaptor RT2 Max Video Capture
Water will not spray
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rt2
Aug 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Rt1=54788 can u tell me what year this is thanks
http://www.flickr.com/photos/tom-margie/2268764021/
according to this site it is a 1971, while a rt2 is a 1972. I have a dt2 yamaha 250 and it is a 1972
Aug 08, 2009 | Yamaha DT 360 Motorcycles
Toshiba Satellite P200 RT2 won't startup
Try to remove ram memory and put it back after a while, do it on removed battery. Ram should be very strictly putted in its sockets.
Mar 23, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite P200 RT2 won't startup but is holding a charge just fine. Power light, charge indicator, battery indicator appear normal, just nothing on the screen. Please help.
Hook up an external monitor and see if windows loads up, if so it might be a backlight or inverter. if you dont see anything then it might be a hardware failure
Mar 20, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a Toshiba P200-RT2 laptop and I am trying to use my webcam on MSN and when I click to send my webcam invitation is says that my webcam is in use or not plugged in. I have tried signing on and off...
First go into control panel, click system and go to device manager. Make sure there are no conflicts when the web cam is plugged in. Is this webcam built into the laptop or via usb?
Thanks,
lee
Jun 17, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
