Question about Panasonic Heating & Cooling
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
    New Friend:
  • 148 Answers
To display memorized error (Protective operation)
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
My Panasonic inverter split zircon with r410a blin - panasonic error codes-xt1cn2hhaugflni22i0hbhn0-4-1.png
Posted on Apr 28, 2017
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
R22= 70-80psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ... Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Water leaking from unit
possible low pressure of refrigerant and freeze coil indoor unit, check filter maybe it's dirty
Jul 07, 2015 | YMGI R410A Ductless Mini Split 16 SEER DC...
I have a R410A Inverter Split system that has stooped suddenly and is now displaying E1, what does this mean/ Thanks Lorena
Not 100% sure but an E1 error on a unit which is sourced from the same place as Electrolux air cons, means that the pipe sensor on the indoor unit has failed. You will need to confirm this with Electrolux. They carry a 5 year warranty, so you may be in luck.... hopefully
Jul 16, 2011 | Electrolux Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
My Ac wont turn on becauser the timer light is blinking Panasonic inverter R410A
use the remote to retrieve error code,on the bottom of the remote you will see a CHECK bottom,use a pointed pin to press it for 5 seconds the display of the remote will change to two underscore, then scroll the arrow beside the time,r press until you hear beep sound, then jot down the error code..there's a error code you will see inside the panel of the indoor unit,for quitting press again for 5 seconds the Check bottom
Aug 22, 2010 | Panasonic CW-1006FU Air Conditioner
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Indoor unit runs ok outdoor unit compressor and fan do not start
Hello rfrizzell,
My unit is giving me the same alarm. If you have found the solution, please email me at
Thank you very much.
Mar 14, 2009 | Friedrich MR18Y3F Split System Air...
Heating & Cooling Logo
91 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
