Question about Garden
My self propelled mower will not get gas to the engine from the primer button
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Posted on Aug 29, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Can't get gas to start primer pump not working
Sounds like you have an air leak in the fueling system and air, not fuel is being sucked in to the primer, check the fuel line and primer pump gaskets or bubble (if it is the primer bubble type)
Aug 01, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
Why isn't the carborator not getting gas?
if mower has been sitting the jets could be clogged up or float my be stuck. if mower is used often there may be a hole or rip in primer bulb
Apr 18, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Engine starts sputters then shuts off
probably a dirty carb. or if this problem is occuring when the engine has been run and is hot and its the new style easy start engine with auto choke ( no primer or choke lever) then the auto choke unit coud be faulty
Aug 21, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Will not start in cold weather
ITS PROBLEY NOT SET UP TO RUN IN THE COLD MOST OF THEM ARNT
Oct 08, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
