Daikin RXYMQ48MVJU need diagram of boards to locate terminals C+ and C- to troubleshoot for code U2
3 Suggested Answers
  • 109 Answers
SOURCE: U2-40 code
CLEAR THE ERROR
Enter SIM
# - * - C - * - 16 - START
Posted on Apr 03, 2010
jasondonohue
  • 6 Answers
SOURCE: solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Posted on Jun 20, 2012
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Help with u2 code on phaser 7300
U2 is an engine EEPROM failure - you'll need to replace the main board to fix that, I'm afraid.
Jan 08, 2013 | Xerox Phaser 7300DN Laser Printer
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Solution for u2 error
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
I have a daikin split air conditioner after been on for 10mins it flashes L1 and cuts off,we have been waiting 4 weeks for Blueline to replace the boards as they said that was the problem since they...
Very simple. Please follow these steps.
1. Power off. 2. In three phase compressor terminal or in terminal block-interchange any two wires.
Now power on and start. Hope, you will be happy.
Feb 26, 2011 | Cfm Daikin R410a Split System Air...
Is there a reset button on daikin splits? If so where can I find it.? Fault code U4.
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Dec 02, 2010 | Cfm Daikin R410a Split System Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
U2-40 code
CLEAR THE ERROR
Enter SIM
Mar 31, 2010 | Sharp AR-M237 Copier
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
22 people viewed this question
k24674
