Question about The Computers & Internet
Where do I put the key code at? - The Computers & Internet
Put in correct code shows error code so wont open. The override key is inside the safe. This dummy put it in there. I know the passcode is correct. Batteries are good.
ouch.... that key needs to be kept outside the safe. when you put in the known code are you pressing A or B after it. On my safe the code is entered followed by pressing the A or B key which was not part of the code.
Jan 14, 2016 | Home Security
How to put 0 on blaupunkt2030
You use:
- "1" key to enter first digit of code (i.e. if first code digit is 5 you have to push "1" until it shows 5 on your display)
- "2" key to enter second digit of code
- "3" key to enter third digit of code
- "4" key to enter fourth digit of code
- "6" key to confirm code
Aug 02, 2015 | 2001 Peugeot 206 1.6
Soedo fuel gauge and water gauge not showing key does not flash lights when presed does not fire up citroen picaso 2lt diesel 2005
the ignition has a reader on it so when the key is in the ignition it reads the key that has a code in it of a key chip in the fob part of the key there are 3 types of keys. a cheep way to find out if there is a code still on the key is take it to have a new key cut. they put it on a reader to get the cod. if it has a code then it is the reader in the lock at fault. then that is something to do with either the immobilizer or the key reader. dropping the key or magnetizing the key can damage the code stored on it, to get the code back on the key you need to go to citron outlet with all you doc's for the car and the pass key. can charge anything for this code to be put back on or in the key.
Mar 27, 2014 | 2005 Citroen Xsara
Chevy knock sensorundefined
hold down mile reset button and put key in and turn one time untill dash lites come on 30 seconds remove key and hand from button now put key back in and start car your done code shound go away
May 22, 2013 | Ac Delco Vehicle Parts & Accessories
My Audi A4 went onto safe mode and I put the wrong code into the radio. It has now gone back into safe mode and will not let me put in the correct code. How do I reset completely?
Wait one hour before attempt to put again the correct code!!! Now the radio is under anti-theft protection. IMPORTANT NOTE: You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
The sequence of programming for 1997 Audi A4 radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Please do rate my response. Thanks!
Jan 09, 2011 | 1997 Audi A4
I accidentally put ON the phone code and i forgot the code
try hard reset..that will be remove all and that phone password
Hard reset is better for solved that problem..
First swith off you phone,after swith off,click *,3 and green key(call key)---->hold,
After to hold that key,now click power key to swith on --->*,3 and call key must hold...
Try it :)
Jun 02, 2010 | Nokia N95 Cellular Phone
The box codes please virgin media in bristol may 09
try these codes
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
To enter the codes
1 - Press menu
2 - Press 1570
3 - Make sure key emu is on
4 - Enter nagravision
5 - Make sure it says ntl at the top box, if not press right till it says ntl
6 - Key number should be on 00
7 - Go to key data and put this code in To enter the codes
1 - Press menu
2 - Press 1570
7 - Go to key data and put this code in *******************
8 - Go to key number and press right so its on 01
9 - Press down so you are on key data and enter this code ******************
10 - Press ok to save
11 - All done8 - Go to key number and press right so its on 01
11 - All done
May 22, 2009 | StarTech.com StarView SV211K 2-port KVM...
Star view codes
V. M. is 5A 01
THEN in the 00 section
put in code 28 8B 84 9C BF E2 71 15 (NEW)
then in the 01 SECTION put in code 1E DF 47 38 4F FB 0B ED
NTL UK 54 01 KEY 00 = 00= F6 7B FE DC 6C 31 75 50 (NEW)
KEY 01 = 01= 96 48 36 06 60 11 5C 4A
Oct 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
PASS CODE FOR A Bluetooth
Hey dude,
U dont need to search for the pass keycode. It is the key u put on. Put on the same code on bluetooth which u have put in ur mobile/PS3.
moz-screenshot-4.jpgSend me a feedback. And Rate me if my solution is helpful !
May 11, 2008 | Samsung WEP170 Wireless Headset
KCD-X590 is looking for a code that i never put in, and i bought the deck brand new
Method of clearing the programmable security
code (KDC-MP632U/X590)
1. While "– – – –" is being displayed, press [->> ] key for at
least 3 seconds while pressing [AUTO] or [TI] key.
This makes "– – – –" display disappear.
2. Using the remote controller, input "KCAR".
Press remote controller [5] key 2 times (Input for "K") and
then press [->> ] key.
Press remote controller [2] key 3 times (Input for "C") and
then press [ ->>] key.
Press remote controller [2] key once (Input for "A") and then
press [->> ] key.
Press remote controller [7] key 2 times (Input for "R") and
3. The security is released and the unit enters the STANDBY
mode.
4. If a wrong code is input, the unit goes into the Code Re-quest
mode.
Oct 14, 2007 | Kenwood KDC-X590 CD Player
Computers & Internet Logo
21 people viewed this question
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
