Question about Power Computers & Internet
Mydell tablet latitude 10 st2 error code 2000-0333 how do I fix it
I can power it on put in my pass code hit enter it goes to the start up menu but if you take to long to hit enter or if you even hit a button on the screen it will go to the shut down mode
  • 213 Answers
SOURCE: cect p168C will not power on
  1. Turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  2. If that doesn't work, connect it to the iPhone charger and let it charge for at least 10 minutes. Note: iPhone 3G does not support FireWire and will not charge from any FireWire-based power source.
  3. If that doesn't work, toggle the ringer switch to see if the unit vibrates. If it does, it could be that iPhone is getting power, but is not displaying any image. (see "Display has no backlight or dark screen" below for further troubleshooting.)
  4. While connected to the iPhone charger, try to reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPhone until it is fully charged.
Posted on Oct 16, 2008
  • 179 Answers
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Posted on Nov 17, 2008
  • 54 Answers
SOURCE: Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Posted on Mar 08, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
Posted on Aug 22, 2009
  • 389 Answers
SOURCE: Dell Monitor shuts down with "entering power save mode" command
There are times when you need to install software for a monitor to work with a PC. If you have the software disk that came with the monitor, you can try to install. You can also try changing the power cord to the monitor. Generally, power cords for PC's and monitors are the same. If you use your PC power cord and the monitor comes on saying that there is no connection with a computer, and it was not doing this before, you can get a new power cord for the monitor. If you can, try the monitor with another PC or laptop to rule out a bad monitor.
I hope these suggestions have given you a place to start and that they were helpful.
Posted on Jan 24, 2010
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
Turn off tablet by pressing and holding the power button until the tablet switches off.
Press the volume up button and keep it pressed while pressing the power button to start the tablet again.
The tablet should enter the Engineer's mode, displaying a text menu.
Use the volume button to scroll the menu and the power button to select an option.
Carry out the Reset To Factory option to delete everything.
Apr 04, 2016 | Kocaso MX1080 10 1 Inch Tablet Blue
How to unlock rca tablet
1. Turn your tablet off.
2. Hold volume up and power button at the same time.
3. Wait until the android dog screen pop up and then the android upside down with a triangle in it will come up the you hit reboot with your volume up or down button and press power for ok.
Mar 01, 2014 | Tablets & eReaders
Dell tablet dont go pass the dell sign when i turn it on
Power on the system and immediately press the Power + Security (Ctrl-Alt-Del) buttons simultaneously for a
second. This will allow you to run a diag on the hardware. Do all the tests. If all passes, then you may need to reload the operating system.
Nov 18, 2013 | Dell LATITUDE-ST-128-R Latitude St Atom...
Part of screen doesn't work
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 21, 2013 | Coby Kyros MID7022
Put an pass code on my tablet and now I done forgot the pass code and can't get back on it.
yo uneed to call the manufactorer. they have a backdoor code that will get in. They will ask you all kinds of questions first to be sure you are the real owner.
Dec 23, 2012 | Tablets & eReaders
Replaced Drum Cartridge - Alarm light still on and still says "replace Drum Cartridge. How do I reset?
Try this procedure, it should help fix the problem,
Turn Printer off. While holding down Enter and Menu keys, power the printer on. You should see PCU Diag Mode displayed. Hit Menu key 6 times till Counter Set is displayed. Hit Enter key Dev xxxxx displayed, left 3 numbers are blinking. Hit (down triangle symbol) till numbers are 000. Hit Menu key, right 2 numbers are blinking. Hit (down triangle symbol) till numbers are 00. Hit Menu key. Drm xxxxx displayed, left 3 numbers are blinking Repeat steps 7-10. Dev tm xxxxx displayed. Repeat steps 7-10. Drm xxxxx displayed. Repeat steps 7-10. Life xxx displayed. Life should be set to 005. Hit Menu key. TNL xxx displayed. TNL level should be between 90-110, if you have problems, try changing TNL. Hit Enter key Counter Set is displayed. Hold down Form Feed key and insert blank paper into manual feed slot. You should get a beep confirming reset. Power printer down and back up, you are done.
Oct 06, 2010 | Sharp FO-4400 Fax
My dell latitude D610 does not hibernate. the option is there but it does not work.
fix ur os errors with reg in out registry cleaner and then do this Insert operating system disk in drive.
Click Start. Click Run. Type
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files.
Sep 21, 2010 | Dell Latitude D610 Notebook
Channels lock
If you forget your pass code, you can view the locked
TV without entering your pass code. When you are
prompted for your pass code, press the number 9 and QV
buttons on the TV remote control at the same time. This
process temporarily unlocks the TV
When entering the Parental Lock menu, this process
deletes your old pass code and prompts you to enter a
new pass code. Press EXIT to exit the menu.
Jul 05, 2010 | Mitsubishi WD-65731 65" HDTV
Mitsubishi WS-55859 power light comes on and then goes off.
I get an error code of 2- 2 x 10 etc Ten times I saw two blinks of the on light. I had a power relay replaced in the year one ,fixed it.then. what do I do now to fix it. What part would you replace thanks.
Dec 22, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Computers & Internet Logo
26 people viewed this question
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
