I HAVE AN AUDIOBANK ABS300BT. The touchscreen is not working
I have tried top reset. Will try to disconnect totally from power supply. What else can I do
SOURCE: remote not working after disconnecting battery
If car Convenience Control Module(module that control key remote) lose power- remote adaptation to the car will be lost. This apply to some Audi models.
What you can try to do is:
1. Disarm alarm manually by opening door lock with the key
2. Put key into ignition and turn to on position (don't start the car)
3. Press few times remote button (with the ignition in on position)
Depends on your year model it my work (works on the newer models), if not you have to go to the dealership to program your keys.
Grzesiek
Posted on May 22, 2009
  • 125 Answers
SOURCE: Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
Posted on May 30, 2009
  • 9 Answers
SOURCE: touchscreen not working
You may be able to go the TomTom website and download the last update programming. If the problem is software this should fix it.
Posted on Jun 22, 2009
  • 10 Answers
SOURCE: touchscreen wont work
touch screen wont work,
what is it doing ?
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Posted on Jan 02, 2010
sharcnet
  • 2130 Answers
SOURCE: Touchscreen is frozen. Tried reseting and
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Apr 13, 2010
Not have sound
If you have just lost sound and the TV has displayed no other problems, Try the fallowing.
Disconnect from power source for 20 minutes and allow to completely cool down. ( Note, you will need to totally disconnect the Power )
Disconnect any external devices
Power the unit on and enter the menu setting.
Look for reset unit to factory defaults. ( If you have that in the menu )
If this works after sitting, your all set.
If this does not work and you still have no sound, you may have a power supply problem and will need to be serviced.
May 27, 2014 | Pioneer PureVision Pro-1000HD 50 in....
Gaggia Platinum Vision no power
You are correct it could be any of the possibilities you have mention.
It is worth checking the two thermal cutouts on top of the boiler.
These can be accessed by removing the top cover only.
If you press the center of the resets and you hear a click you have found the fault
Jan 22, 2013 | Gaggia 74845 Platinum vision coffee maker...
Hc 21 camcorder touchscreen problem
Please follow the troubleshooting steps provided below and check the operation:
1. Rotate the screen and check if that helps.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
Jul 04, 2012 | Sony Video Cameras
Garmin 660 touchscreen inoperative
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 18, 2011 | Garmin Nuvi 660 GPS Receiver
Hello i forgot my germin nuvi 350 gps password can you please help me how to reset it Plzz
To perform a Master Reset on the nuvi 300 series, follow these steps:
  1. Start with the device OFF and unplugged from the power source.
  2. Use your index finger to press and hold the top right corner of the touchscreen.
  3. Power the device ON while continuing to press and hold your finger to the top right corner of the touchscreen.
  4. After the device powers ON, release the power button. Then you will see the message: Do you really want to erase all user data?*
  5. When this message displays, remove your finger from the top right of the touchscreen and touch Yes.
  6. The device will now go through the Reset.
  7. Follow the onscreen instructions to set up your nuvi.
After the nuvi is set up, if indoors, please go outside to allow the device to acquire the satellite information. Ensure that the device has a clear line-of-sight with the sky.
*If this message does not appear when using the top right corner of the touchscreen, please repeat these steps using the bottom right corner of the touchscreen.
May 30, 2011 | Garmin nuvi 350 GPS Receiver
Computer turns on.. no post.. no activity
First, disconnect the cables from the motherboard to the hard drive, optical drives and floppy (if your computer has one). Also remove any expansion cards that are installed. If your computer has a separate video card installed, remove that as well and let the motherboard use its integrated video. Of course, if the board doesn't have built-in video you can leave the video card in. What you want to do is remove anything that may be causing the motherboard not to start up properly.
Power up the computer with all that disconnected and see if it starts up and posts. If it does, one of those disconnected parts is holding the system board down. I have seen this happen because of bad drives or cards, and even once a bad data cable. You can then reconnect the pieces one at a time and try powering on the computer. When you reconnect the guilty part the computer won't start, and you'll know what you need.
If the computer still doesn't start with those parts disconnected, you have a bad power supply, RAM, processor or the motherboard itself. Remove the RAM and try starting. If the memory is causing the trouble, you should hear the BIOS beep error for bad or no memory. If that works, reinstall the RAM one stick at a time to determine which is causing the trouble.
If there's no response when you take out RAM, try substituting another power supply. Many times the supply isn't working properly even though the system comes on with the power switch. People often overlook a bad supply unless the system is totally dead.
If this all still doesn't get the system going, you probably need a system board. It's possible the processor is bad, but I see bad motherboards far more often. Usually capacitors start to go bad and the board no longer resets properly. Sometimes you can see failed ones with bulging or split tops. It's not usually worth the effort of trying to repair the board, unless it's a proprietary OEM board or a very high-end board.
Good luck tracking down the trouble, and thanks for using Fixya!
Dec 15, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Touchscreen and charge
As far as the battery not holding a charge goes, some batteries have a memory, so the amount of current you recharge becomes the total charge available. Some other batteries just don't recharge nearly enough times to be worth it.
Jun 03, 2010 | Archos 605 WiFi Digital Media Player
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off...
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Jul 15, 2009 | E-Machines eMachines Desktop PC
Fully charge unit- Why is not getting sattelite reception?
are you outside with an unobstructed view of the sky ?
have you tried a reset ?
if both have been tried, consider a master reset
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
To perform a Master Reset on the nüvi 3xx, follow these steps:
  2. Use your index finger to press and hold the bottom right corner of the touchscreen.
  3. Power the device ON while continuing to press and hold your finger to the bottom right corner of the touchscreen.
  4. After the device powers ON, you will see the message: Do you really want to erase all user data?
  7. Follow the onscreen instructions to set up your nüvi.
After the nüvi is set up, go outside to allow the device to acquire the satellite information. Ensure that the device has a clear line-of-sight with the sky.
Mar 17, 2009 | Garmin Nuvi 350 Car GPS Receiver
Palm TX power button and touchscreen
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Jul 06, 2008 | Palm TX Handheld
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
