Question about Toshiba MW26G71 26 in. TV/VCR/DVD Combo
The tape player wont accept any tape
I put a tape in and then the player just pushes it back out
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Retime the gears. help it in
Posted on Jul 18, 2010
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Jul 30, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
Sanyo Stereo Cassette Recorder M7300K will not record and record button vey hard to push down
Make sure the tape you are trying to record to is not restricted (unrecordable or pre-recorded). You can look at the tabs on the top narrow band and if they are punched out the tape will not accept recorded material. (you can put scotch tape over the hole and still record but only if you are desparate!)
Oct 22, 2009 | Audio Players & Recorders
Wont play tapes, makes clunking sound
Tape? What's a tape? Just kidding. I agree with chryslerpro. Look on ebay for an exact replacement. Consider maybe upgrading to cd's instead. Good Luck
Apr 14, 2009 | 1999 Jeep Grand Cherokee
Vcr won't accept tape
My husband was able to fix the problem. It turns out that the sensor switch was jammed. He used a piece of duct tape to block the signal while putting in a tape. The tape went in and still worked after he removed the duct tape. I have recorded and played a tape, so all is well right now.
Dec 25, 2008 | Sylvania SSD803 DVD Player/VCR
VCR accepts tape, then turns off
I think that there is something wrong with the tape you are using. The locking mechanizm is stuck and when the VCR can't turn the reels it will eject the tape. I'm assuming that you didn't try other tapes to see if it acts the same. You can unstick the locking mechanizm by putting a pencil or something like it in the 1/4" hole between the reels on the back side of the tape. Just try pushing down on that brake release. This has worked for me. Good luck.
Jul 04, 2008 | Zenith XBV243 DVD Player/VCR
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
Camera won't accept tape
tape senors is bad or have a bad tape
Jul 31, 2007 | Sony Handycam CCD-TRV308 Camcorder
Toshiba MW26G71 26 in. TV/VCR/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
