Question about Dell Tablets & eReaders
Dell latitude10 st2 tablet error code 2000-0333 how do I fix this problem
I can power the tablet on put in my password hit enter it goes to the start screen the it will shut down
2 Suggested Answers
mrhappyface
  • 205 Answers
SOURCE: polaroid tablet 4.2
hold down the power button until it shuts down or remove the battery or just unplug it and let the battery die
Posted on Mar 24, 2014
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
Put in wrong password for wifi and then accidentally hit forget and now it wont let me type in a password at all
You need to select the wi-fi website again, and enter the password again. It will then store the password.
If you forget the site, it forgets the password connection to the site and you have to start again.
Feb 14, 2014 | Kocaso 1.2GHz 4GB 7 inch Capacitive...
Owner doesn't know the passwords. At power on, it has two icons, 1 is on top of a can like icon, and the other is a padlock. Because I don't know the password, I hit the F1 after I power on and the...
hi,
Thinkpad has a very powerful protection, and entering or trying to enter or access it multiple times will cause it to lock completely, and you will need to change the system board - in other words : you need a new heart or brain for it
because the code you post is for the EEPROM checksum is not correct
so, dumping it might be a solution if you don't have anything important to back up, and even if you did, Very hard to retrieve
hope this helps
thanks
Oct 19, 2013 | Tablets & eReaders
Pattern attempts
If you have it linked to an email account, then if you enter your password 5 times you should get a forgot password button. Click it and follow the prompts to reset the password. You can also reboot the tablet and hold either power + vol up or power + vol down to get a menu with the option to factory reset the tablet. This will erase all data too.
Jun 23, 2013 | Dell Streak 7 WiFi Tablet
When Im going to connect my external keyboard to the thinkpad tablet 2, it ask me for the password. A password that have never been provided.... Anyone who know how to proceed
I had the same issue, and i resolved it by:
1. Typing the code '0000' + Enter on the tablet screen, making the tablet check
2. Hitting the same code '0000' (and maybe Enter, don't remember) on the keyboard right after.
..then the tablet paired the keyboard correctly. Good luck!
Jan 23, 2013 | Lenovo ThinkPad Tablet 2 Bluetooth...
Acer travelmate c110 blue screen , how to fix it
If windows won't boot and if you have tried the safe mode and "Last Known Good Configuration" mode, then try the procedure below and repair the windows installation files.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Jan 15, 2010 | Acer TravelMate C110 Tablet PC
Password
This is a BIOS password, to disable it,
Boot Your Computer
Enter the Password
Hit F2 (BEFORE YOUR COMPUTER BEGINS TO LOAD WINDOWS)
This will bring you into BIOS menu, find where it says "Set Supervisor Password" or "Set System Password"
Either disable the password, or when it prompts you to change it, simply hit enter without entering any characters and this will get rid of it.
Jan 26, 2009 | Toshiba Satellite R15-S822 Tablet PC
Bios setup password
Hi!! Usually DELL Latitude or Inspiron passwords are storedi n eeprom memories that has to be read or writen to remove / bypass the BIOS password!!! Password generate a hash code that will appear after 3 wrong password attempts and it has a 5 digit decimal format "xxxxx" You can get the hash code by pressing F2 or F10 when you turn on the laptop to enter Bios and then when password prompt appears hit F12 to get the hash code.
You can generate a unlock code or master password with the service tag "xxxxxxx" 7 digit, this code appears at the password promtp screen or at the bottom of the laptop with a white sticker.
I got Latitude D620 Bios password Unlocked at http://www.laptoprebirth.com They can calculate a master password with the hash code. Hope it helps
Oct 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
Top Dell Tablets & eReaders Experts
Michael Vincent Cruz
brian soufane
Tiffany Tosh
Level 1 Expert
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
