50 amps 3 phase converted to kwh - Heating & Cooling
  • 537 Answers
SOURCE: 3 phase sunbed
You have to get a 3 phase circuit put in. Call an electrician. Some electricians may not even know how to do 3 phase power though. Call around.
Posted on Dec 13, 2007
handygirl911
  • 65 Answers
SOURCE: Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
Posted on Jun 09, 2009
  • 110 Answers
SOURCE: This is a 3 phase
no not without changing mtr. contactors,installing a roto-phaseinverter is the way to go dont get static inverter
Posted on Jan 09, 2010
  • 165 Answers
SOURCE: can i convert a 3 phase 10hp qrs compressor to single phase?
Search the 'net for phase converters. I have read articles about making your own phase converters from old 3 phase motors----Fine Woodworking mag.
Posted on Feb 28, 2010
al_kupchella
  • 843 Answers
SOURCE: how can one use a
You need a phase converter. The link below is a a selection from Grizzly. You can also find them on e-bay. There are two types - static (no moving parts) and rotary (much more expensive). The rotary type give you full performance delivering true 3-phase power to your machine. But for a minor loss in power (maybe 20%) the static type does the job quite well - assuming you don't need all of the power that your 3-phase motor can deliver. Here's the link: http://www.grizzly.com/products/category.aspx?key=275030
good luck. Vote if you found this helpful. Al K
Posted on Sep 09, 2010
Alternator bad diode
is this a question,?
1: is mine bad, how to test it or find it, in the global sense?
2: where to buy one.
3: which brands are best.
4: how to do a basic diode test , front to back ratio testing.
5: what are the symptoms of a bad diode.
ill throw the ice 2+3 = 5.
the Modern ALT has many diodes. (and more{in dah reg})
the 2 main, sets are , the 3 phase set.
and the keep alive pack.
ill not cover the keep alive pack or the regulator diodes..
the 3 phase pack take the 3 AC phases and converts them to Pulsating DC. (in effect simulating a DC generator)
if 1 diode opens , you lose, 1/3 of the total power.
so 50 amp alt is now a 33 amp alt. (weak as a cat)
if the diode shorts, it becomes this huge noise generator.
(turn on the AM radio , here it sing and raise pitch as you gun the throttle (i use a scope to see bad diodes) bingo.
the noise can in fact cause any electronics on the car to go nuts.
the diodes also have one other feature, ill skip here, (zener actions)
Nov 19, 2013 | Suzuki Cars & Trucks
I have an ingersol rand 2420n5 t30 and i want to convert it from single phase to 3 phase any help thanks
Hi robles212
To convert your T-30 to single phase you will have to do one of two things.
1. Change the motor to a single phase motor
2. Buy and install a "Phase Converter" to convert 3 phase to single phase
Please rate me
Bud
Oct 08, 2012 | Ingersoll Rand Type 30 Reciprocating Air...
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
How to convert the aircondition tanage in amp
I assume you mean tonnage. If you are looking for the amp amount to run a circuit to your aircond. here is rule of thumb: 2 ton is a 20 amp circuit (requires two 20 a breakers for a 230volt single phase unit)
3 ton is a 30 amp circuit (230v 1 phase)
4 ton is a 40 amp circuit (230v 1 phase)
5 ton is a 50 amp circuit (230v 1 phase)
all these require two breakers, and both breakers should be joined together.
May 11, 2011 | Heating & Cooling
Muh108 single phase what size breaker to use 40 or 50 amp
IF it is 10KW at 208 single phase it should be on a 60 Amp breaker.
3 Phase would be 35 Amps. Always check the nameplate for additional information. It may be configurable for different voltages. Best to check manufacturers data if available.
Mar 05, 2011 | QMark MUH-35 Heater
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
How can one use a 3 phase wood lathe in a residential area where single phase power supplied. Have 50 amp breaker supply to shop. What is required to hook up 3 phase Centauro TC 1200 (Italian wood lathe)...
Sep 09, 2010 | Garden
For an 3 Tn unit- single phase- 220 V a.c and gfor
There should be a full load amps or rated load amps on each of these units on the rating or nameplate. The ampacity or fuse size and wire size, which I think that's what you are wanting to know . The fuse size would be full or rated load amps times 125% and the wire size depending on the length of the run, 50 feet or less, (15 amps 14 gauge wire), (20 amps 12 gauge), (30 amps 10 gauge), and (40 amps 8 gauge).
Aug 11, 2009 | Heating & Cooling
Can i convert a 3 phase 10hp qrs compressor to single phase?
Apr 26, 2009 | Chicago Pneumatic Qrs 5 HP/3 Phase Rotary...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
