Question about Garden
Weed eater pe550 wont start,not getting spark replaced ignition module and spark plub
SOURCE: Where can I find a manual for the PE550 weed eater
i have a weed eater edger and the starter rope broker
Posted on Aug 23, 2009
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
  • 89 Answers
SOURCE: String-trimmer (weed eater) won't start.
the only thing left is the coil that is inside the cover right next to the flywheel with a gap of 10 thousand of a inch a business card will work but a new coil is almost thr price of a new trimmer unless you have a used one
Posted on Nov 05, 2009
Testimonial: "Thanks for the help. We did look at the coil. Got about 30 volts out of it when we pulled the starter. I hope that means it's OK."
  • 1545 Answers
SOURCE: why does my primer bulb when pushed stay push in
You may have a clogged in tank fuel filter, lines in the tank broken off of the fuel filter and line fragments clogging the fuel lines. . Fuel lines get flaky when they deteriorate. Your primer bulb may be leaking also. The check valves in the carburetor control the flow of fuel in and out of the primer bulb. The carb may need cleaning. In other words, a complete fuel system assembly inspection will be needed. If the bulb is on the carb, the check valves in the base assembly below it may be sticking. Remove bulb and spray in there with WD-40 to free frozen or sticking check valves. The valves are very small and malfunction occasionally
Start your inspection at the fuel tank and work your way to the carb. Pull the cover off the carb on the end opposite the end with the vent hole in the cover. You will be pulling off the fuel pump cover. Inside the carb body you will find a very small round fine mesh screen. Clean it well with carb cleaner and when you reassemble, spray some WD-40 in that area too.
Posted on Nov 11, 2010
SOURCE: Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Posted on Jan 10, 2015
To change the blade which way does the nut turn to get it off? Clock wise or counter clock wise?
Most weed eaters are opposite to conventional thread. So they are CLOCKWISE to take off
Apr 30, 2016 | Weed Eater PE550 8-1/2-Inch 22cc 2-Cycle...
I have a PE550 Weed Eater Edger and have new carb, new fuel lines, new ignition module, new gas filter, new gaskets, and new air filter.... and it still won't start, what should I do now?
Theres a screw for gas and air mixture on it you need to turn it all the way in then turn it 1 and a half times out , its a perfect factory setting the push primer 3x and turn on choke pull 2x then turn off choke should run hope this
Sep 28, 2013 | Health & Beauty
No spark on Weed Eater FB25 25cc Gas Blower
Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
My sthil fs 80 has new carb and new rings. has spark but wont start
Is fuel getting into the cylinder.? Is the spark continuous, check gap between flywheel and ignition module. 0.25 filer guage.
Mar 04, 2013 | Stihl FS 85 Weed Eater
My Stihl FS 85 Weed Eater gets no fire to the spark plug
older models have a pick up and condenser for spark. newer models have pick up and ignition module. the pick up rust the condensers and modules go bad. first take apart to expose flywheel then ck for rust on flywheel at pick up if rusty clean set pick up clearance to that of a matchbook or ten thousands of a inch.if still no spark change condenser or module.
Jul 14, 2012 | Stihl FS 85 Weed Eater
Very weak do I check the points under the fly wheel.....How do I get the fly wheel off? I just picked any weed eater product cause there was no link for my weed eater ride on mower with a...
Unless your engine is more that 25 years old (not possible for an Enduro), there are no points. The ignition is solid state, which means that a weak spark will require a new ignition module. Not the end of the world - they're cheap and easy to find.
Change the plug first!
Feb 17, 2010 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jun 28, 2009 | Poulan Pe550 Gas Edger
You can download one online at... Scroll down the right side to 'Download Manuals'...then enter your model #.. you can then download the owners manual or parts manual. Dwain
May 21, 2009 | Poulan Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
