Question about Garden
Have Briggs17.5hp intek 31G777 Eng on mower,have replaced f/wheel key,valves,coil,checked carby still it back fires thru carby,timing seems ok.What else can I do to make it run instead of backfire.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 903 Answers
The valves are not set correctly. or the valve seat is out of its seat.
Posted on Apr 24, 2017
Why won't engine fire ?
has motor got compression are valves still opening is plug getting wet with fuel, have you changed plug, sounds like you have checked fly wheel key hasn't sheared
Jun 27, 2014 | Parks Optical 13.5hp Briggs And Stratton...
Riding mower keeps back firing and will not start
you have a sheared timing key it is under thefly wheel replace says the red neck
Sep 01, 2013 | Briggs AND Stratton Intek Briggs &...
Kawasaki 25hp back firing through the carby and exhaust
My name is Dane and I am going to help you solve your problem.
Normally, when an engine backfires through the carburetor, It will be from a valve problem. You should first adjust the valve clearance looking also for any bent valves or pushrods.
The other thing I would check would be your flywheel to make sure it hasn't sheared a flywheel key, and check your coil and gap. This is doubtful, but worth a look if the valves check out ok.
I hope I've helped! Thank you! Dane
Dec 30, 2010 | Garden
Hi just got a 13.5 briggs do i have to power up the grey wire from the carby cheers john
Yes. It should get power when you turn the key to run, this lets fuel into the carby. When you turn the key to 'off ', it cuts the fuel off. The black wire in the same plug (on the other side of the engine near the starter motor) goes to the coil and is the engine kill wire which is connected to the ignition key switch and gets earthed out when you turn the key to 'off '. Dont make the same mistake I made and have it connected to earth all the time, the engine wont go at all! Aussie Steve.
Dec 17, 2010 | Parks Optical 13.5hp Briggs And Stratton...
17.5 briggs intek backfiring thru carb wont start have adjusted valves?
Easy things to check, flywheel key, make sure it is not broken, check the coil gap to the flywheel. could be the coil is not advancing. Check, if it has one, the oil sensor by unplugging it. hope this helps.
Apr 14, 2010 | Parks Optical 13.5hp Briggs And Stratton...
17HP Briggs Intek engine ran good then quit. Now
Intake and exhaust valves need adjustment. Intake .004, exhaust .012.
look for wear or loose rocker arm bolt before adjusting valves.
Nov 22, 2009 | Briggs & Stratton Garden
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
