Question about Staples Tools & Hardware - Others
How do you load staples into a Rapesco AV 39 grey non swivel stapler ?
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Posted on Mar 14, 2009
jesusandsean
SOURCE: TRYING TO LOAD A STANLEY
Have you looked at the spring for possible loss of pressure.
Posted on Mar 05, 2011
SOURCE: I have recently been given a Powershot 8000
With the staple exit facing toward you (don't squeeze the handle), find the small black square at the bottom (opposite end) from staple exit. Grasp both sides. Pull away from gun (not down). Chamber will open.
Posted on May 21, 2011
SOURCE: We have a Swingline Giant
The triangular plastic section at the rear is the end of the staple tension/feed assembly. Grasp it, push inward and lift upward to release it, then pull it rearward and out of the stapler. Insert staples and reinsert the feeder and lock it in place again.. ready to go!
Posted on Jun 02, 2011
My brand new stapler suddenly stopped folding the staples. It just shoots out singles; good for bulletin board posting-not for stacks of papers. Can this be fixed?
The item on the bottom that folds the staples has two positions. Press it up from the bottom and swivel it 180 degrees to folded staple setting.
May 13, 2016 | PaperPro Compact Stapler, 15-Sheet...
Rapesco 813-D stapler. What staples will fit?
try rexel for a replacement, they might do the job.
Aug 09, 2015 | Staples Tools & Hardware - Others
HOW TO LOAD A RAPESCO MODEL 55
I know this is an old question, but in case anyone else needs to know - there is a large black button at the back (on the top) of the stapler. Press that and the staple magazine pops out.
"For older models (AV-29 & AV-39) remove the feeder at the rear of the machine and feed the staples into the rail and then replace the feeder. For newer models (AV-45, AV-55, AV-59, AV-69 & AV-79) press the button at the rear of the product which releases the magazine (at the front of the product) and drop the staples into that magazine then push the magazine closed."
http://rapesco.com/faqs/
Oct 11, 2013 | Office Equipment & Supplies
Rapesco 853d stapler
i have rapesco 853-d staple gun but none of the 8mm staples fits in
Jun 16, 2013 | Tools & Hardware - Others
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Has anyone found substitute rexel titan No 37 staples for the rexel titan tacker gun yet. The No 88 staples although they fit the gun do not fire as they are not fine enough .The original No37 ones are...
Rapesco Part number is: S14082M3. I've used these without problem
apparently Rapesco has now changed to Tacwise and they are now sold as
Tacwise 0346 (Type 140)
Oct 09, 2012 | Office Equipment & Supplies
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
I need a user guide for a rapesco 53el staple gun
Rapesco have been absorbed by Tacwise Worldwide. www.tacwise.com should give you all the info you need. The model numbers haven't changed, so you should still get info on the 53 series electric stapler.
Apr 01, 2011 | Tools & Hardware - Others
Tools & Hardware - Others Logo
112 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
