Question about Electrical Supplies
What psi does a clarke g1200 1100w generator need?
I have a clark g900/700w generator.i started up today.started ok but when i turned the choke off it started to cut will only run on half choke thanks
Is the gas fresh?
Possibly stale gas is the problem
Has engine been serviced: clean air filter, fuel filter, spark plug.
Clean out fuel system with carburetor cleaner. Place about 12 oz. in fuel tank and run engine.
Oct 29, 2013 | Clark Electrical Supplies
Where do I go to order repair parts?
Air Compressor Parts & Accs - eBay > Business & Industrial > Light Equipment & ToolseBayAir Compressor Filter Regulator Industrial Quality 0 to 160 PSI. C $41.83; Buy It Now; +C ... Power Ingersoll Rand Impact Wrenches, Ratchets & Tools. C $104.65.
Clarke Air Compressor Parts‎‎rating for
Clarke Air Compressor Parts. Search Now!
Over 85 Million Visitors.
Nov 04, 2011 | Clarke Power Products Inc AC2000 2HP 6...
I want to use a 120psi brad nail gun on a clarke ranger 115psi compressor ..will it be ok
It'll be perfectly fine. Wear safety glasses with them nail guns, they can really send a nail flying.
Dec 29, 2010 | Clarke Power Products Clarke Pioneer 2 Hp...
Hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Jun 22, 2009 | Electrical Supplies
Where can i buy replacement spark plug for clarke generator please
Go to your local saw shop. Hope this helps you, Rick
Apr 27, 2009 | Electrical Supplies
Ihave a g900 clarke generator that runs perfect,smells of petrol
Hi i have the same unit, i believe that this is just after fumes that actually smell very much like petrol. As this happens to mine as well and the cap is a very tight seal. Its very much like the smell of an old petrol lawn mower.
Do you know which way round the 240v plugs go.... for instance, which pin is positive (live) and which pin is ment to be negitive (neutral).
As you can put the plug in either way it just seems wrong??
Mar 31, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
