Question about Tablets & eReaders
All of a sudden, daily now, my tablet will start to battery drain rapidly even if on the charger. To temporary fix it I use SD Maid, wipe system & dalvik cache. What causes this?
2 Suggested Answers
  • 192 Answers
SOURCE: I have used less than a GB of storage space on a 16GB Nextbook tablet and when I try to download a program that is 2.1KB it says I do not have enough storage space how do I fix this?
is it possible you have a partition on your storage and are attempting to download in the smaller section of the patrician,
Posted on Feb 03, 2015
Testimonial: "You cannot choose between partitions of storage space and you can't choose between SD card or internal memory. I have found something about this being a common problem with the Nextbook 7 model and there is supposed to be a firmware update for it but I cannot find it. Thank you for the suggestion but I have tried selecting what memory partition to use and it doesn't give you any option of where to put the program you are trying to download either."
The battery in my Samsung SM-T320 tablet has started to drain with little use. How can I tell if I need a new battery or a new charger and cord?
When it is plugged in to charger. Does Samsung show battery is charging? Can you set it so battery % is displayed. Try another wall socket. Try another charger or cable.
Sep 14, 2017 | Samsung Tablets & eReaders
I have not be tablet I downloaded a movie of google play cannot find the movie on my tablet to play offline
install an app like SD Maid, it has a fikle manager that givs you access to all downloads. or install Download manager, same idea...
Sep 07, 2015 | Tablets & eReaders
My nextbook 8 runs well if I leave it plugged into the charger but shuts off soon after unplugging even with a full charge.
It could be the battery is already on its end of life. Could be, your charger can't deliver enough power to work and charge the tablet. Before you start worrying, please leave the tablet on a charger over night, with everything switched off. Then remove it from the charger and start it. If you keep having the same problem, and you can't check the quality of the battery, start saving for a new tablet. Not worth paying 100 dollar for replacing the battery, if you can buy a new tablet for the same price. If you can open the tablet, check if the battery is still connected correct.
Dec 27, 2014 | Tablets & eReaders
My tablet only stays charged for 5minutes
Check battery, battery plus should have it and can check it
Jul 18, 2014 | Tablets & eReaders
My tablet won't power, only shows battey then shuts off, won't charge
Most likely a dead battery or bad charger. Test and/or replace the battery or charger.
May 10, 2014 | Noria 7 Android 4.2 Tablet - White
Playbook totally drained power cannot charge
The problem may be with your charger, Micro usb cable or your micro usb port. The blackberry playbook rapid charger uses the little brass buttons to charge and will help you diagnose if the problem is with the playbook battery or if the problem is with the micro usb connection.
Feb 17, 2014 | Tablets & eReaders
Cant get my samsung tablet to turn on
Your tablet's battery is probably dead. This may be because you have a bad battery, a bad charger, or a bad charging cable. Try using a different cable first and let it charge for a few hours - even if it doesn't look like it is charging.
If the new cable doesn't do it, try using a different charger. Samsung devices are picky about what charger you use, so try to use one made for your tablet. If you don't have another charger, plug it into a PC's USB port with the PC turned on. Leave them on and plugged in over night. That should trickle charge your tablet.
If neither of those work, try holding down the power and the Volume Up buttons. Keep them both pressed until the Samsung logo/boot screen comes up - should only be a couple seconds. Once the logo comes up release the power button but keep holding the Volume Up button. That will boot you into Recovery Mode. If that comes up, it means you've got power and your tablet isn't broken, but there is something wrong with the Android OS that is keeping your tablet from powering up normally. Use the Volume Up and Down buttons to move the selection highlight to the Factory Reset option. This will wipe all the info off your tablet and put it back into a "brand new just out of the box" state. You'll lose your information on the tablet, but this should fix the boot problem. Press the power button to chose the Factory Reset option. It will take a few minutes. Once it says that it is done, select the Reboot or Restart option. It should reboot. This boot will take longer than normal, since its wiping things out. But not more than a few minutes.
Jan 02, 2014 | Samsung Galaxy Tab Tablet PC
Can't find temporary recovery log
the only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
May 28, 2013 | Tablets & eReaders
My samsung galaxy tab from yesterday suddenly gone off. i am trying restart but not starting and even i made full of charge. but indication of on i dont know how i reboot or reset to start. please...
When its off condition
do Volume Up + Power-button for 3 secs you will see a screen with exclamation mark with android and some font written in Blue
Do wipe data using Home key to select and volume keys to navigate
then do reboot to system i think it shd fix your issue.
Apr 04, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
44 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
