Question about Samsung Cell Phones
Linking LG HBM-570 to Spotify on Samsung Galaxy 6
  • Cathy Moneysmith
    Cathy Moneysmith Apr 24, 2017
    I can't get it to link. Any ideas? It will link to phone calls.
award462
  • 395 Answers
SOURCE: LG HBM- Bluetooth- need to find how to link
Strat with headset 'OFF' then hold power button until light flashes blue and red or solid blue, then search for headset on phone, pass key should be 0000, 1111, 1234.
You can get the manual by searching for the FCCID, which should be in the headset https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Posted on May 05, 2010
mediastormer
  • 135 Answers
SOURCE: I just need to know
lg-mobile-phone-accessories-hbm-570-3-4view-large.png 0000
Posted on Oct 25, 2010
SOURCE: I have a LG HBM-570 blue tooth and the ear hook
Here is a website to get the replacment ear loop you are looking for... Looks like it is a common piece that breaks often.. :(
http://www.amazon.com/gp/product/B003WTBY88/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B003KSAYQY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0WJRMHB0BYCCN9MG4BE4
Posted on Dec 13, 2010
  • 149 Answers
SOURCE: My blackberry curve recognizes the
Hi, to solve this problem, you will have to do some troubleshooting.
First you will need to disconnect the pairing of both the blue tooth headset from your black berry phone.And pair again with the below instruction.
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
After that if still does not work that means you will need to test if the bllue tooth headset is really not damaged by using it on another phone to confirm.
You can also reset the blackberry cell phone if still not working. Blue tooth might be corrupted and will not connect to headset. You can use the below instruction to reset cell phone:
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
When you are through with that and still nothing happens, then you blue tooth headset needs replacement..
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Feb 18, 2011
  • 149 Answers
SOURCE: how to make auto answer
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Posted on Mar 02, 2011
How to Transfer Contacts from HTC to Samsung Galaxy S8/S8+
Phone to Phone Transfer can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. So, you can easily transfer contacts as well as any other data from your old HTC phonet to Samsung Galaxy S8/S8+ by using this tool.
How to Transfer HTC LG Sony Huawei Data Contacts to Samsung S8 Edge
Apr 26, 2017 | Samsung Cell Phones
Ok, lets try it this way I want to purchase a used android & turn it on using tracfone pre-paid servive. what brands of cell phone can I purchase?
http://tracfonereviewer.blogspot.com/p/tracfone-byop-phone-list.html
Tracfone BYOP 4G LTE GSM (AT&T) Phone List:
Samsung Galaxy S7 - various options on Amazon
Samsung Galaxy S6 - various options on Amazon
Samsung Galaxy S5 - 16 GB on Amazon and eBay
Samsung Galaxy S3 - 16 GB on eBay
LG G2 - 32 GB on eBay (refurbished currently $139)
LG G3 - 32 GB on Amazon and 32 GB on eBay (refurbished currently $189)
LG G4 - 32 GB on Amazon
Moto G 4th Gen (latest version) - 16 or 32GB on Amazon
Nexus 6p - 32, 64 or 128GB available on Amazon
Nexus 5x - 16 GB on Amazon
Motorola Moto X 4G LTE - 16 GB on Amazon
Motorola Moto G (1st gen) 4G LTE - 8 GB on Amazon
HTC 1X - 16 GB on Amazon
Blu Stdio 6.0 - 16 GB on Amazon
Asus ZenFone 2 - 16 GB on Amazon
BLU Studio C Super Camera - 8 GB on Amazon
iPhone 6 and 6 Plus - 64 GB iPhone 6 on Amazon - 64 GB iPhone 6 Plus on Amazon
iPhone 5s - 16 GB on Amazon
iPhone 5 - 16 GB on Amazon
iPhone 4/4s
Nokia Lumia 640 (Windows Phone)
And many more options, let us know in the comments what you are using!
Tracfone BYOP 3G and 4G LTE CDMA (Verizon) Phone List:
Motorola Moto G (4th Gen) 16 or 32 GB on Amazon
iPhone 6 - 16GB on Amazon (64GB and 128GB also available)
iPhone 6 Plus - 16GB on Amazon (64GB and 128GB also available)
iPhone 5 - 16GB on Amazon
Samsung Galaxy S5 - 16GB on Amazon
Samsung Galaxy S4
Samsung Galaxy Note II - 16GB on Amazon
Samsung Galaxy Note III
LG G2 - 32 GB on Amazon
LG Lucid
Nexus 6 - 32GB on Amazon
Nexus 6p - 32, 64 or 128 GB available on Amazon
Nexus 5x
Moto X 2013 Edition - Amazon
Motorola Droid Razr M
iPhone 4 - 8GB or 16GB - Find on Amazon and eBay
iPhone 4S - 16GB or 32GB - Find on Amazon and eBay
Motorola Droid 1
Motorola Droid 2 - Find on Amazon
Motorola Droid 3 - Find on Amazon and eBay
Motorola Droid X
Motorola Droid X2 - Find on Amazon and eBay
HTC Droid Incredible - Find on Amazon and eBay
HTC Droid Incredible 2 - Find on eBay
Samsung Fascinate - Find on Amazon
HTC Rhyme - Find on Amazon
HTC Trophy (windows phone) - Find on Amazon
HTC One M8 (windows phone)
Moto G - Find on Amazon and eBay (we have one report suggesting a user got a used Verizon Moto G that had been active on Verizon prepaid for 6 months, and was able to activate with Tracfone, more feedback appreciated!)
Jan 08, 2017 | Android Cell Phones
Bluetooth LG HBM-235 to samsung phone
normal pairing passcode for any bluetooth is 0000
May 25, 2012 | LG Cell Phones
Need user guide for lg hbm 570
click here
if it helps please leave a 4 thumb rating.
May 28, 2011 | Cell Phones
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
The plastic ear piece broke on my LG HBM-570 Bluetooth® Headset, is there anywhere to get replacements?
I had the same problem and I contacted LG first by email, this was the response: Please contact our Customer Care line at
1-800-793-8896 Ext 2, and they will be able to assist you with a
replacement. I called the number and they agreed to send me a replacement piece free. I got it in 5 days. May I also suggest that you ask for a manual to be sent also because I cant seem to find one and I would love to activate Name Alert for caller ID during drive time.
Good luck with that.
Aug 12, 2010 | LG HBM-760 Bluetooth Headset
Apr 30, 2010 | LG HBM-760 Bluetooth Headset
Cell Phones Logo
59 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
