Is there a aux audio output apart from phono connection
simplemitch
  • 752 Answers
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Posted on Sep 12, 2007
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
  • 104 Answers
SOURCE: Connect a phonograph turntable to a receiver w/o phono connection
you will need a little box called a pre-amp. This hooks up between the turntable and newer receivers without a phono input. A basic explaination & drawing of this type of setup can be found here
http://www.turntableneedles.com/Pre-Amps_c_4.html
Posted on Apr 17, 2009
cjackHD
  • 71 Answers
SOURCE: I have a Bose Wave, Multi CD changer and wish to
The only other solution for this would be to connect the red and white RCAs directly to the source that you're trying to hear. (i.e. cable box, dvd player etc.) I have seen a convertor that will go from digital coax to RCA, but I'm not sure how reliable it would be. Plus a good one would be very expensive for what you're trying to do. You could also get an RCA switcher. Connect all or your components (cable box, dvd etc) to the switcher, and an RCA output to the Wave system.
Posted on Jun 21, 2009
  • 86 Answers
SOURCE: No audio output or output voltage on 70v terminal
it sounds like you have a power supply problem
try and check for a blown diode inside close or
around the transformer.
maybe this will help.
Posted on Oct 17, 2009
Why does my UREI 1620LE hiss on phono channels and aux 4 channel ?
are you using a phono pre on the phono channels?
Sep 15, 2014 | Music
I want to connect my stereo
Your TV must have a sound output, preferable an RCA type output jacks, these are connected to aux or line inputs of your audio amplifier, in some TV sets, you must deactivate speakers at menu to have audio at these outputs, please check your TV user guide for more details.
Sep 11, 2012 | Cars & Trucks
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
May 27, 2012 | Audio Players & Recorders
How to connect an aiwa music system to sony dvd player
Just plug the audio output of the DVD to audio input(AUX) of Aiwa system. Select the player in the Aiwa( Aux, DvD, and Phono)
hope that helps out!
Jun 09, 2011 | Aiwa Audio Players & Recorders
How to hook up a turntable to a pioneer vsx-1019
receivers with a PHONO input can connect a turntable easily by just connecting the white and red stereo audio cables from the turntable to the phono inputs on the receiver. receivers without a PHONO input can still connect a turntable by using a phono-preamp whose output can connect to any analog stereo input on the receiver like CD or AUX. See this webpage for more info:
http://columbiaisa.50webs.com/turntable_to_pc_hookup.htm
May 02, 2011 | Audio Players & Recorders
How do I connect a technics turntable to an RX-V463 AV reciever? Thank you in advance
Modern AV receivers rarely contain PHONO preamps.
A traditional turntable requires a preamp inline with it to PRE amplify and frequency-balance the minute signal produced by it's cartridge. Most stereo receivers and preamps have Phono connections and internal preamplification strictly for that purpose. Yours does NOT.
A standard turntable will require you to acquire an external PHONO preamp to place between the TT and an Aux connction on the receiver.
Some of the newer turntables come with selectable internal preamplification to solve the lack of it in modern equipment. If your turntable is that type you can select its internal preamp output and run that to an AUX input.
Jan 15, 2011 | Audio Players & Recorders
I have a Pioneer PL-S50 turntable that I want to connect
hi you need a Phono Input Attenuator Line Adapter
the above link is for one on ebay but they are also available through radio shack
Jan 06, 2010 | Denon AVR-689 Receiver
Can I connect a power amp to this unit?
If your 2100ES has a selectable INPUT AND OUTPUT and if you're intending to send all signal to the power amp, i.e. not bi-wiring or using the 2100ES to run mid-range or treble then you simply send Left & Right audio (White & Red cable) from a 2100ES output, probably AUX OUT ( it doesn't really matter apart from Phono on some units) straight to the power amp on AUX IN.
We should be just dealing with audio here, so connect the NAD audio output to CD or DVD IN. Select CD or DVD IN on 2100ES input switch and switch output to AUX OUT (whatever you decided goes to the power amp) on the 2100ES. Turn power amp to AUX IN and it will now get an audio signal from the 2100ES for amplification.
Speakers connect to the power amp as a normal amp, so pos and neg etc. The 2100ES now only acts as a signal feed, the power amp does all the work.
So, summary - switch on the NAD, press play - video goes separately and audio goes to the 2100ES. Turn 2100ES to INPUT for NAD. Turn 2100ES to OUTPUT allocated for power amp. Turn INPUT on power amp to allocation for 2100ES.
Turn it up!
Jul 27, 2008 | Sony STR-DA2100ES Receiver
Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Nov 03, 2007 | Audio Players & Recorders
24 people viewed this question
 Grubhead
Grubhead
