Question about Light Garden
I just bought a new battery but my white outdoor tractor will not turn over-battery indicator light comes on but will not even click. What next?
  • 62 Answers
SOURCE: Toro lawn tractor : tractor will not start
On most riding mowers there are several switches that must be actuated before it will start. First, make sure that blades are disengaged. Also, if there is a handle that engages and disengages the blades, you might try holding it in the dis-engage position in case the switch is out of adjustment. There is probably one under the seat also. This switch kills everything if you are not sitting in the seat for safety reasons. The switch here could be out of adjustment or mis-positioned. Also, make sure the parking brake is set, and the gear is in neutral, and not forward or reverse. Also, even if the parking brake is set, you might try pressing the brake all the way down while starting, as this switch might be out of adjustment. All of the switches should be easy to locate and adjust. Also, you should check the battery. It is possible that you left the key on by mistake and drained it.
Hope some of this helps.
Posted on Oct 07, 2008
  • 109 Answers
SOURCE: 12.5 HP Troy Bilt riding garden tractor. Battery
There is also a safety switch on the brake pedal, it could also stop the mower from starting
Posted on Apr 26, 2009
  • 672 Answers
SOURCE: 2002 envoy 4wd problem. clicking sound comes and
Clicking sound- Possible electronic fan clutch failing. This is a typical problem with the 4.2L I6. When you hear the clicking, open the hood and listen if its coming from the fan clutch on front of the engine. this could also cause abnormal engine and transmission cooling. As for the "N" light and 4wd issue, have scanned at the dealer....Hopefully this helps
Posted on Jul 18, 2009
  • 188 Answers
SOURCE: Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Posted on Jul 23, 2009
  • 867 Answers
SOURCE: 92 FXR bike will not start or even turn over
that clicking sound is the starter solenoid. check all large cables for corrosion and tightness. as for the signal lights, neutral and horn, i think a wire is grounding , thus causing the problem with the bike not starting also. check at ignition switch and at handle controls for a loose wire that may be touching the handlebar. basically inspect all the wiring on the bike
Posted on Aug 08, 2009
I have a Harbor Breeze White 3-Speed Combination Fan and Light Control (Model #: WC-100L) that has stopped working. The red power light does not even light when I push the buttons. Any idea on...
First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
Oct 17, 2013 | Dryers
Just bought a John Deere d140 had it delivered by home depot. Went to turn key, tractor completely dead. Lights won't even turn on. Looked in manual says to charge battery. What do I use to charge this...
are you pressing down the clutch/brake pedal? is the pto switch turned on?are you sitting on the seat?the lights only come on while its running not with the key turned on
Apr 30, 2012 | John Deere Garden
Will not start
I have a feeling what happened was you shorted out the ignition switch, somehow. If you can get behind the switch without much trouble, try to jump the wires together 2 at a time just to see if it will jump the , lights, starter, ignition, one of the 3. or get a voltage tester, it will do the same thing. There is a fuse on there in the line, sits next to the battery. check it. Hope this helps,
May 06, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Hi I just bought a 2004 Mazda 323 and I had to turn the key twice to start it. The next day it wouldnt start at all until I charged the battery with jumper cables. The third day it wouldnt start again even...
if you go by the green light on the top of the battery that is a false indicator it only shows the one cell of the battery it is in,so that cell could be good and the rest could be bright were the lights when turned on,I would take the battery out and have it checked out.If you do have a new battery installed then have the alternator checked also just for piece of mind if the alternator is going bad it will kill a new battery fairly quickly.Ill be will to bet it's just the battery I hope this helped good luck
Jan 03, 2010 | 1993 Mazda 323
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Dash board lights on grand voyager flashing when engine on. car would not start so charged bat over night. Then bought a new bat. have changed battery and still happening. Did altinator test lights dipped...
the controls always click when you change the setting as it is electronic, don't panic, but you should ask your ex as he is well up in voyager' s and the back seat not folding down properly!!!!!
Jun 20, 2009 | 2000 Chrysler Grand Voyager
Just bought a 2001 vs800 intruder,got it home and will not start
If you're getting no lights then it is either the ignition switch or the battery is not making connection. Check the battery with a multi-meter. Check the fusebox with a multi-meter, any power to any fuses there with key on?
Jun 16, 2009 | 2000 Suzuki VS 800 Intruder
White Outdoor Lawn Tractor 2150
It sound as if there may be a short near the ignition switch.
Aug 25, 2008 | Sport & Outdoor - Others
Garden Logo
27 people viewed this question
Top Light Garden Experts
Dennis Key
Dennis Key
Are you a Light Garden Expert? Answer questions, earn points and help others
