Question about PRINTER Office Equipment & Supplies
How to disable a privacy separator on my talktalk super router
I cannot print on my Epsom 342 printer
I had replacement TalkTalk router installed now can't print wirelessly via KindleHD to HP2544 PSC.I've reinstalled compatible HP printer app to Kindle. HP & Amazon tech teams are blaming each other!
new router . be like jerking ruG out from team of clown jugglers
no>?
is printer on wifi? some can be connected 3 ways.
but not one word on this.key fact.
learn find true cause
use say a real PC
any real PC (no a kindle is not a real PC its a toy)
then get the PC to print, load driver. lean.works.
see printer works. end, goose chase?
proves router works, and pc, and the printer wroks
the printer will have to be rejoined to the router
all in one printer
chapter 7 , in users guide here?
http://support.hp.com/us-en/product/HP-Deskjet-2540-All-in-One-Printer-series/5295960/model/5385260/manuals
click chpter 7, how to setup printer to new router
just start at step one, like you bought all toys new
Jan 23, 2017 | HP Computers & Internet
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
Have an Epsom stylus color 440. will not print
I'm trying to do a print nozzle check on my Epson Stylus Color 440 printer that I have but a pop-up box say "Error, can't print". Why is this?
Oct 06, 2009 | Epson Stylus Color 440 InkJet Printer
900.80 Service RIP Software
install your printer driver again....
May 20, 2009 | Lexmark X642e All-In-One Laser Printer
Delete print queue in epsom stylus c46
Hi
Go to control panel, click on printers, look for stylus c46 icon, right click and cancel all documents. restart your computer afterwards.
Thanks for using fixya!
Oct 31, 2008 | Epson Stylus Photo R1800 InkJet Printer
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
107 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
