How many PC's can be connected to an SPS? - Computers & Internet
2 Suggested Answers
greg_margo
  • 1959 Answers
SOURCE: sps 1000 - pc connection
The usb port isn't in your cash register. Your cash register has a serial port that should look like this: 70b547a.jpg
You should have a cable that has a USB connector at one end and a port that will accomodate a cable like pictured above.
Posted on Apr 16, 2009
Service Air Bag light on
DTC B0058 Right Front/Passenger Pretensioner Deployment Loop Open.
The passenger seat belt pretensioner deployment loop consists of a seat belt pretensioner-RF and the seat belt pretensioner-RF high and low circuits. A shorting bar used within the seat belt pretensioner connector shorts together both the seat belt pretensioner high and low circuits when the connector is disconnected. This will help to prevent unwanted deployment of the pretensioner during servicing. During a frontal crash of sufficient force the inflatable restraint sensing and diagnostic module (SDM) will allow current to flow through the deployment loop in order to deploy the seat belt pretensioner. The SDM performs continuous diagnostic tests on the deployment loops to check for proper circuit continuity and for shorts to ground or voltage. If a malfunction is detected, a diagnostic trouble code (DTC) will be stored in memory.
DTC B0084 Left Front/Driver Seat Position Sensor Circuit
The inflatable restraint seat position sensor (SPS) is used to determine the proximity of a front driver or passenger seat position with respect to the frontal air bag. The SPS interfaces with the sensing and diagnostic module (SDM). The state of the SPS allows the SDM to disable stage 2 of the frontal air bag for a front seat that is forward of a forward/rearward point in seat track travel. The SPS is a hall effect sensor that is mounted on the inside seat track of both the driver and passenger seats. The seat track includes a metal bracket that shunts the SPS magnetic circuit creating 2 states of seat position. The shunted state represents a rearward seat position. The non-shunted state represents a forward position. The SPS provides 2 current ranges, one range for the shunted state and a second range for a non-shunted state. These 2 states are inputs to the SDM. State 1 (shunted) being the rearward threshold and state 2 (non-shunted) being the forward threshold. When the SDM receives input from a SPS that state 1 threshold is reached (seat is rearward) the SDM will not disable stage 2 deployment, if required by the deployment sensors. When state 2 threshold is reached (seat is forward) the SDM will disable stage 2 deployment on the side the seat is forward. The SDM monitors the SPS circuit and if a fault is detected the SDM will set codes B0083 or B0084 and defaults to disabling stage 2 frontal deployment. This will only default on the side of the vehicle the sensor has a fault. Its important to understand that the SPS is secondary to the passenger presence system (PPS) and the manual instrument panel (I/P) module disable switch. If either one of these devices are in the disable mode the passenger air bag will not deploy regardless of the SPS status.
You should take this to a qualified repair Shop ! Takes special tools to test .
Feb 26, 2016 | 2006 GMC Envoy
How many PC`s can be connected to an sps
Not that is is necessary but the more you use the shorter the time before the power supply runs down and you loose power.
Apr 24, 2014 | General Computers & Internet
Samsung sps 1000
I Have the Samsung SPS 1000 Program Manual in pdf format which shows all key combinations. I will send it to you if you let me know by email. computershack.leo@gmail.com Have a great day.
Feb 08, 2014 | Computers & Internet
DV6000 GT375EA#ABU Only powers on from its battery
I have had the same issues with my HP dv6208 laptop. I ended up sending my laptop in at their expense to get it fixed. My suggestion to you is to go to the HP support website and chat or call them. The dv6000 series laptops had several issues with the MB and wireless card. they should replace the failed part for free even if the laptop is past its regular warranty. HP extended the warranties on several of these laptops in this product line because of the failures. You have to tell them the serial number, product number and model and they tell you wether it is covered or not. Otherwise I am pretty sure you are looking at a new motherboard for your laptop. Hope this helps...
May 12, 2009 | Computers & Internet
Sps 1000 - pc connection
Apr 16, 2009 | Microsoft CompuRegister POS-1000 POS...
Im having trouble installing the sps-600c alpine speaker system. i need a wiring diagram or somthing as im un farmiliar with split speakers that dont have a cross over.
Hello lucal_s2000,
Well, actually those 600c's do have a crossover. It's encapsulated in the wiring you got with the components. Your head unit or amp speaker outputs connect directly to the woofers. The inline crossovers have a 12" wire on one end and a 22" wire on the other end. Connect the 22" side to the 2nd set of terminals on the woofers, and the 12" side to your tweeters, keeping all of the positives and negatives straight.
Here's an image of the connections.
5eca958.jpg Hope this helps.
Apr 12, 2009 | Alpine SPS-600C Car Component System
Computers & Internet Logo
David Payne
David Payne
