Question about The Office Equipment & Supplies
Cant undo the head holder in the valley. also how do i lift it off by hand
How to get to the piston
Big job and if you need to ask that question, I would doubt you have the tools and knowhow to accomplish, UNLESS you want a big learning experience with Clymer manual in hand.
If you want to look at the top of the piston for some reason, remove the air filter, plug leads and anything attached to the cylinder head. Undo the rocker cover bolts and remove. Remove the Timing Belt. Undo the cylinder head bolts and lift the head off.
If you need to replace a piston, it is much more work and starts with 'remove the engine'.
Why do you need to 'get to the piston'?
Oct 22, 2015 | Cars & Trucks
Cant find manual on line
what machine is this for?? i doubt you put 4 stroke in with the petrol!! usually you mix 2 stroke oil with unleaded fuel at a ratio of 50-1
so 100ml of oil in 5 litres of fuel. If your trying to completely remove the striming head then usually they are a left hand thread, so turn it clockwise to undo it
Mar 08, 2015 | Garden
How do you Remove head unit 1990 holden barina
First drain water . remove cables from plugs and any thing attached to the head. Remove valve cover, remove valve rocker. remove manifold. undo head studs , undo from the center working one stud at a time from left to right of center. lift off head.
Aug 16, 2014 | Cars & Trucks
25 hp yamaha outboard powerhead removal
Remove Cowl ,Undo Four Bolts Securing Lower Cowl,Then Undo Bolts Securing Power Head, Disconnect All Attachments To Power Head From Cowl +any Electrical Connections ,Lift Power head Out
Mar 07, 2013 | Boating
Is there instructions for replacing the MP730 printhead (QY6-0064-000 ) anywhere?
Remove Ink Cartridges Lift grey lever to the right side of the cartridge holder to the up position.
The print head should lift out nicely. You may need to squeeze sides of the cartridge holder slightly to the center in order to clear the outer print head assembly.
May 03, 2011 | Office Equipment & Supplies
I am unable to lift out the empty cartridge as the catridge holder stops in a position where I cannot lift the cartridge out
AHH har -- mine does that , try open the application in the PC (or Mac) - click ink check, then cartridge replacement , and in my case EP6000 the print head moves out of the way.
There is also an envelope lever on the right hand side and by sliding this back and forth it moved the print head - Ray
Jan 20, 2011 | Epson Printer
I have a compaq cq60-300ev , with a sempron amd drive, how do i replace my ram ?
turn the laptop on its head under the bottom there is a small square plate with a small screw at the top undo the screw and you will see the ram card holder laying down gently lift it pull both metal clips to the side as you extract the ram card and replace as per reverse.
merry christmas
Dec 22, 2010 | Compaq Presario Notebook
Brushes dont spin
You will have a slipping or broken belt turn brush by hand have machine off check if belt is broken if it is replace with new. undo brush holder and brushes should come out there may be more screws to undo after the brush holder but very simple job. good luck
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How do you remove and replace the radiator of a 1997 EL Ghia?
first undo the hoses, there are 4 water hoses and 2 oil hoses, the bottom hose is difficult on the high side because of the alternator.
un plug the 2 wire connections (don't forget the locking tabs) then undo the air duct held by 2 screws. followed by 2 bolts located on the top of the radiator and lift the fans straight up
there are 2 larger bolts that hold the radiator in at the top. lift straight up.
when replacing be sure to place in locators in the bottom of radiator and fans
Mar 08, 2009 | 1983 Ford Fairmont
24 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
