What tv stations does this pick up - Televison & Video
Do the Kodi tv box pick up the regular tv stations ?
Yes! Kodi does pick up regular TV stations and standard live TV channels. See the video tutorial (attached to this Answer).
Here's our written guide on How to Install TV Addons via Config Wizard:
Install TV Addons in Kodi VIDEO Tutorial KodiFireTVStick com Tutorials
To install TV Addons for Live TV channels, we recommend installing the Config Wizard in Kodi. Attached is our video tutorial on how to do this on Kodi that's running on Amazon Fire Stick, although you can use this same process for any device that's running Kodi.
Jan 06, 2017 | Televison & Video
Can't change channels stuck on 4 tried scanning it but it goes back to 4 won't change on the tv or a remote
When you run a scan the TV changes to every channel and tries to tune in a station. that is why it takes so long. If your TV is only finding channel 4, I would guess that is the only station strong enough for it to pick-up. You should check and / or replace your antenna and or antenna cable. Then re-scan the channels. with a better antenna, it should find more stations.
Most older Tube type TVs need a converter to pick-up digital TV, if you have a converter, make sure it is plugged in.
You should not be getting any stations without a digital tuner TV or a converter box.
The FCC site says this:
The FCC established September 1, 2015 as the date for the termination of all analog low-power television service. Since that date, analog television should no longer exist in the United States. Until that time, LPTV stations were allowed to continue to operate their analog facilities.
Jan 28, 2016 | Televison & Video
Www curtisint com
If the tuner is weak, this kind of fault can occur. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 24, 2014 | RCA 24V511T 24" TV
We have a mitsubishi 1080 hd model ws-48311. We no longer have cable do we need a converter box for this tv to pick up free tv. Thank you
No. All you need is an inexpensive antenna to pick up local TV stations. If the stations are close, all you should need is something like this one: http://www.walmart.com/ip/RCA-Digital-Flat-Antenna-made-for-DTV/10542272
Sep 09, 2013 | Televison & Video
My digital tv will only pick channel 10, abc and sbs, even though it used to pick all channels?
U trying to pick up all free AIR DTV tv stations wright?Yes.This problems u have a weak airial antena.Buy a better antena like a Digital antena or a roof antena for hook up.Tries again,will pick up all DTV free AIR tv stations.
Apr 03, 2011 | Televison & Video
Speakers picking up tv or radio station when volumn is down
Well, sometimes these components can act like antennas. Do you live near a radio or tv station antenna? Or near a highway, or where truckers are near...might be CB'ers. Also, sometimes, in older houses with 2-prong only AC wall sockets. Also, yo don't want your speakers too close to your own TV, or cell phone, or computer itself, as this can cause interference to get into your speakers. Just some ideas.
Apr 23, 2010 | Logitech X-240 Computer Speakers
I HAVE A DIGITAL ANTENNA AND I WHEN I DO A CHANNEL SCAN IT'S NOT PICKING UP ALL THE CHANNELS HOW DO I GET ALL THE CHANNELS
It has to do with the distance and direction of the different TV station antennas. You have to have a strong enough antenna, and you have to aim it at the TV station's transmitter.
Apr 19, 2010 | Memorex MLTD2622 26 in. LCD TV
Why can't i get digital audio stations on my Akai lct374zad TV. I've scanned several times and it only picks up the digital video stations.
i dont know but tv stations comes with sounds and video syncronize.then you will need a digital radio to get digital sounds from radio stations.good luck.
Mar 01, 2010 | Televison & Video
Picking up tv station
Yes, lock out the frequency, or wait until digital broadcast comes int effect. DTV will be effective in 2009 where all television broadcasts must be done by cable or satellite. This means no antenna broadcasts.
Mar 17, 2008 | Uniden BC60XLT-1 Handheld Scanner
TV trouble
Option called SAP has been activated.....in audio menu...
select stereo, not Second Audio Program................T.
Dec 19, 2007 | RCA F32650 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
