Error code 5A - Computers & Internet
Error code 5a
What is your make and model of Laptop?
Jul 14, 2016 | Computers & Internet
I have a carrier window ac error coad 5a flashing for some time ac not on
Find model number and research error codes for that unit. Or try a "hard reset" by turning off breaker for one minute and turning back on, th his may cleat code
Apr 01, 2016 | Carrier Heating & Cooling
How do I fix brother printer
Error code 5A is a hardware error code:
"The purge cam stops
abnormally when it is in
The purge cam is part of the built in maintenance unit that cleans the printhead and purges air from the ink supply lines.
As this is a hardware error, it cannot be "cleared". Something is physically wrong with the purge cam/maintenance unit such as a broken part or a foreign object has fallen in to the maintenance unit such that the purge cam can no longer revolve.
Even accessing the maintanmce unit takes a lot of effort and skill, and if a new maintence unit is required this will be very expensive and require very good DIY skills to perform. In all proablity, if you contact Brother to get the printer repaired, they will charge you more than the cost of buying a new printer.
Sep 10, 2014 | Brother Office Equipment & Supplies
Error code 5a
plss remove code 5A ,,,,,,,,,,pls help m e
Aug 05, 2013 | Brother MFC-9840CDW Laser Printer
Hi i m using brother printer i am getting error code of 5A
Hello Ankit,
The error 5A you are receiving because the machine does not work due to a paper jam or some sensor problem.
To resolve the paper jam issue visit the link provided below :
Jun 22, 2011 | Brother MFC 210C All-In-One InkJet Printer
Need codes for eurovox 5a 01
These work on 5A 01
8th October
5A 01
83 5D 12 B8 96 F6 1F C4
D2 F9 3F 22 0C A7 D6 C9
Oct 07, 2009 | Televison & Video
Brother MFC-9440CN error 5A print unable
Error 5A unable to print is a problem with the high voltage power supply PCB, or with the engine PCB. A shop could tell you which one after some testing. Expensive repairs...
Jun 29, 2009 | Office Equipment & Supplies
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
