Question about Panasonic Lands Phones
How to key/shift in numbers and letters in panasonic cordless phone KK-TGA431AL MODEL
SOURCE: Cordless phone keypad problem
I too have similiar problem with Uniden phone. In my case it is only the center toggle. I indeed took the phone apart and this problem relates to the metal oxide wearing off the rubber keys that make contact with the exposed circuit lines. This same problem is common with TV remotes. Sometimes you can take apart device and find that cleaning the circuit with rubber eraser can help the problem. You can clean the rubber contacts, but be delicate as you do not want to remove the coating on the key. As far as taking phone apart? Well it helps to be a tech with experience. Usually there is at least one screw or two to remove in the battery area. Then you gently pry the phone apart. Sometimes devices like this slide apart after the screws are removed. If you pry start at position nearest where screws join parts together and work your way up. You may dent the plastic a bit in process. Once you have two halves apart be careful in next steps. There will be numerous screws holding the phone to face. Also be careful of wires to speaker. They are usually hardwired. No plug. As you take apart take careful note of how wires are routed. Also be careful of charge contacts that slide into base of phone.
I could fix my phone if I could get the part, but I suspect Uniden will not sell me the part and ask me to send phone in.
Spinman
Posted on Jan 01, 2008
SOURCE: How do I delete messages remotely from a Panasonic 5.8?
I did not solve the problem, that is why I contacted you. Now you want to charge me, I am disappointed as this is a bait and switch scam. For shame.
Business journalist in Miami
Posted on Jan 04, 2009
anoopsnoop
  • 43 Answers
SOURCE: My keyboard double types each letter, i.e.
Hey,
Goto Start-> Settings-> Controlpanel-> Key board settings
In the keyboard properties, drag the repeat delay slider towards long. Now test the keyboard and try again until the problem in fixed.
Thank you
Posted on Apr 11, 2009
SOURCE: My Blackberry Pearl 8120 will not turn off the
take the battery out and put it back in simple man
Posted on Apr 30, 2009
SOURCE: how to unlock panasonic kx tg1070 cordless phone
Cant unlock phone
Posted on May 03, 2010
Manual for panasonic KK TGD533W
Do you mean the KX-TGD533W? I do not know of any Panasonic phones with KK in the model number.
If you have the KX-TGD533W, the manual is available on the product page: http://shop.panasonic.com/cordless-corded-telephones/cordless-telephones/KX-TGD533W.html . Scroll down to the Support section. The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tgd510_mul_om.pdf . Note: the manual covers several different phones.
I hope this helps.
Nov 10, 2017 | Panasonic Televison & Video
How do I unblock a phone number
You can find the procedure in the programming section of the manual. Look for "Viewing/editing/erasing call block numbers" The Panasonic KX-TGEA20 model number crosses to the additional handsets for your cordless phone, but these handsets are compatible with the TGEA-21X through the -27X series base units. If the [MENU] # code sequence is different you will have to share your exact model number.
The Quick -n- Dir(ect) answer is:
    1.[MENU] #-2-1-7
    2.<Navigator key "up/down" arrows> to "Block a single number" ? [SELECT]
    3.<Navigator key up/down arrows> to highlight/select the desired entry.
    This should offer you the choice to edit or erase, so choose...
    4.[ERASE] ? <Navigator key up/down arrow> to "Yes" to confirm your action? [SELECT]? [OFF] The number should no longer be on the "Blocked" list if you go back in and start from step 1 (above).
    If you have lost your original manual you can get a replacement from the Panasonic FTP site here:
    ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf
    V/R,
    Veg
    If a train station is where the train stops, what happens at my workstation?
    ~Author Unknown
May 05, 2016 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
PHONE CS6629, HOW DO I ENTER LETTERS ON TO KEY PAD INSTEAD OF NUMBERSRS
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
Dec 30, 2013 | Panasonic KX-TG2357 Cordless Phone
Cs6629 how do i enter numbers on to key pad instead of numbers
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
