Question about Bosch Computers & Internet
I can't remove the battery from my Bosch AHS 48 LI ,THE RELEASE BUTTON ON THE REAR OF THE BATTERY DOES NOT work
  • 1019 Answers
SOURCE: Battery don´t work
Replace the charger.
these are usually factory sealed units, and even if you can get the replacement components. probably not worth repairing.
You can purchase a universal charger, with variable voltage. usually between 19-24 Volts variable. ( On E-Bay )
Have you checked the fuse in the Plug?
if you have a multimeter, test that the charger is giving an output to the specified voltage. if it is then you have a motherboard fault, or charging board fault in the laptop itself.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 65 Answers
SOURCE: HP Pavilion dv6225us laptop battery release latch
is the latched stuck in the open or closed position? if it is in the open position you may be able to wedge a pick or small flathead and gently ease it out. if it is in the locked position attempt to use one of these same tools to move the latch to the open position. hope this was helpful.
Posted on Dec 09, 2009
Testimonial: "Thank you. I think I did not have the nerve to use the instruments, because I thought that I would break it. Thanks for your help. It worked. :)"
  • 252 Answers
SOURCE: Bosch Hedge Trimmer AHS 4-16 Starts now and
sounds like you will need to replace starter pulley in the starter cover assy and check that the starter pawls are free to move and the pawl springs are no broken or the pawls are frozen
but your problem is most likley starter pulley
remove the starter cover and check the starter pulley
worn or damage teeth on pulley may be quite evident
cheers pauly46
Posted on Sep 12, 2010
eugbug
  • 479 Answers
SOURCE: Bosch electic hedge trimmer (AHS
If there is a fuse in the mains plug, check this hasn't blown.
Posted on May 13, 2011
  • 236 Answers
SOURCE: is there a fuse for the trunk release button for a 2003 bmw 325i
Yes there is a fuse for the trunk opener.also,do you have a valet switch to shut it off?
Posted on Aug 28, 2012
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
I have a Bosch hedge trimmer AHS 52 LI and yesterday when I tried to fit the battery to the trimmer it would not fit
Make sure that you are using the right battery, positioning it right to match how it goes the receptacle. Last thing is do not be afraid to give it a good push in there. New ones in particular have a firm seating which can take a little bit to get it in.
Feb 20, 2015 | Bosch AHS 52 Li Cordless Hedge Trimmer
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
My th27 loses its frequencies after i switch it off. Can anyone assist, is there an internal battery?
There is an internal Li battery. If the radio loses programming when power is removed or turned off, that battery is dead.
Feb 17, 2011 | Kenwood PB-18,...
How to start since the power button does not react? How to charge battery?
Try recharging the battery. If that doesn't work, try a new battery.
Use the supplied charger to charge the battery. If you've lost the charger, you can get an LI-41C charger from Olympus. You can also get LI-40B or LI-42B batteries from them.
Jan 15, 2010 | Olympus FE-340 Digital Camera
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
Top Bosch Computers & Internet Experts
RudeRude
ray gallant
Brett Duxbury
Brett Duxbury
Are you a Bosch Computer and Internet Expert? Answer questions, earn points and help others
