Question about Janome Sewing Machines
I have a janome serger overlock 8002D the needle get caught on a bar on its way down and I won,t let it go down because the needles will break and I am frieghtend of doing damage to the looper
  • Janome Master
  • 10,245 Answers
Be sure to install brand new needles. A bent/damaged needle could strike and break or cause damage.
Otherwise, you should probably take your machine for service.
Posted on Apr 25, 2017
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
Newhome 743D overlocker. What kind of needles does it use?
From what I can discern, Newhome was a Janome product. Perhaps these needles will work:
Janome Overlock Serger Needles 5 Needles per Pack
Is this similar to your machine? If so, then the needles above may work:
Janome Mylock744D Overlocker Serger
I found some Janome 743D manuals online but they all appear to be in the UK, or elsewhere.
Jul 30, 2015 | Sewing Machines
I just got a new Janome 8002d serger. Why does it make a clicking noise when I begin to serge and then it goes to straight stitching that comes unsewn.
I don't have a Janome, but you might check your threading to see if it's correct, lucky you to get a new one!!!
Mar 05, 2015 | Janome Sewing Machines
Serger Needles
Janome Overlockers (sergers) are set at the factory with #14 Red Tip needles
For finer fabrics, the #11 Blue Tip is good
If the #11 breaks, then try a #14 as they are a little heavier duty
You can always:
Contact Us at Bargain Box
Have a look at the detailed descriptions on these links
Accessories Parts
Apr 20, 2014 | Sewing Machines
Janome 9200d overlocker
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Aug 18, 2013 | Sewing Machines
Can I just change the needle plate on my janome overlocker been told I need to have loopers reset
Sergers are funny things. You can certainly try just replacing the needle.... make sure you thread correctly. upper looper, lower looper, right needle left needle... etc.
Before you take off sewing... run the machine by hand a few revolutions if it seems to be moving with no more clunking etc. try to sew. If it breaks the needle again. Stop immediately and take it in.
Dec 02, 2012 | Sewing Machines
What twin needles do I get for my overlocker ,It is a Janome Mylock 134D Are the needles universal or do I have to get a special one for this machine
I think Janome Mylock 134 has 2 separate needles. They are #11 or #14 for sergers and secured by 2 independent setscrews. I saw on ebay the instruction book with the owner's handbook for Janome Mylock 134D.
Jun 23, 2010 | Janome MyLock 644D
What needles are used by my Janome Model 134D serger?
my overlocker is a janome and i use generic overlocker needles; these are all rounded, not flat on one side. i hope this helps
Jan 29, 2010 | Janome MyLock 634D Mechanical Sewing...
My janome harmony 9102D serger I think is out of
i suggest you get a tech to re-time your machine. timing is complex on an overlocker and if not done correctly you will probably break a looper.
scott.
Jul 21, 2009 | Janome Harmony 9102D Mechanical Sewing...
Sewing Machines Logo
37 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
