Question about Neff Ovens
How to change bulb-holder on neff oven b45e42
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Change light-bulb
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
Posted on May 17, 2007
SOURCE: Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Posted on May 08, 2008
jmeredith
  • 417 Answers
SOURCE: Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Posted on Jun 29, 2009
  • 414 Answers
SOURCE: can NEFF oven be connected using a three pin plug on an independent oven circuit
If is a bog standard single oven then yes, if it has a self clean function or a rapid heat up function then generally no as the current draw would be to high for a 13amp to cope with, if you need model specific verification ring number as per linkhttp://www.neffcustomerservice.co.uk/Neff/CustomerService.html
Posted on Nov 26, 2011
My Neff oven keeps blowing bulbs, immediately a new bulb is fitted it blows like a fuse.
Maybe your First bulb in the oven is a 220 volt bulb not a common 110 bulb? Good luck.. BCB...
Oct 23, 2016 | Neff Ovens
Fully working except no power to light bulb
Check the light bulb it could be bad, but first chek voltage on terminals to bulb holder
May 16, 2015 | Neff Ovens
Lamp Holder
It has to be reinforced
Jul 25, 2012 | Neff Ovens
Can NEFF oven be connected using a three pin plug on an independent oven circuit
Nov 26, 2011 | Neff Ovens
Shelf fitting slot broken off
Use the link http://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?x=0&y=0&Maktx=Neff+U1721&eshoptype=Aenter the FULL enr from the rating plate, don't just pick the nearest one if the enr is U1721N0GB/75 that's the model you need to check as parts from one model to another can vary. This will open a diagramatic breakdown of the oven and you can search for the relevant part (and buy if online direct from Neff). Couple of things to remember, make sure you have the right oven (ie top or bottom) and whether it is the front or rear holder as one is like a keyhole and the other is a keyhole on its side.As this is a build under unit, it does make changing the part a little easier (depending on which one is broken, hoping for your sake that it's not the back top oven one..Argggh!!) You will need to get the oven out and I find it easier if it's on it's side with the faulty holder at the top. The side panel needs to come off (or at least be loose if it's a front holder) as the holders are held in place by a retaining clip behind the cavity wall, or if it is a screw in type, the screws comes in from behind the cavity wall. I suggest you order and get the parts first and this will give you an idea what you're dealing with. Let me know how you go and post any comments or problems you have whilst doing the repair (anything I've forgot to add) as this will help anyone else looking for a solution to a similar problem.Ps. If you are sensitive to fibreglass, wear a pair of gloves.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
hi,,
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Apr 27, 2008 | Neff U1661 Double circotherm super...
Change light-bulb
May 17, 2007 | Neff B1421 Electric Single Oven
Ovens Logo
65 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
