How to solve , No paper jam, but disply show paper jam
tAno179
  • 21 Answers
SOURCE: paper jam
if you cleared the paper jam an your printer still shows this paper jam, you may try this:
1. after you clear the paper jam, turn off an on the printer.
2. if above advice is not working you may try to look more carefully (with a flashlight maybe) if a small piece of paper is not blocking the paper jam sensor.
3. unfortunately this is a job for a qualify serviceman.
4. in less then 2-3 % of cases is a defective sensor, and must be replace by a serviceman.
Posted on Sep 23, 2008
  • 160 Answers
SOURCE: in CLC 1150 When power
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Posted on Jan 06, 2009
SOURCE: Epson Photo RX420 showing paper
I've had exactly the same problem. There was no bits of paper or specks of dust, fluff, etc. Switched on and off to no avail. Eventually I gave it a good old fashioned whack on the sides and switched it off and on again. It worked! The machine is 5 years old and now working beautifully. I don't want to encourage this practice – obviously you don't want to break anything inside so do it carefully, and only after checking all other possibilities.
Posted on Jun 30, 2009
  • 79 Answers
SOURCE: PAPER JAM ERROR MESSAGE keep showing!!
Make sure that all rollers in the paper tray is working properly. If not, then this might be the reason why your having this issue. Try calling your manufacturer to have it replaced, if it's still under warranty.
Posted on Dec 03, 2009
GeoffW1
  • 3961 Answers
SOURCE: my printer shows paper jam when there is no paper inside.how can i solved this problem?
Printers are very sensitive to little bits of torn paper in the paper path. Often you can't see it, but the printer KNOWS. So you have to keep looking. Read carefully the jam clearance procedures in your user guide (usually found on the manufacturer website).
Posted on Sep 11, 2015
Canon ir 2270 having a problem of paper jam but it doesnt show any error code can you help me solve this problem. by Fredy Gabriel
if it has a paper jam. it should show on the display/panel which the position jammed.
then you open up the cover of it..
Jun 08, 2011 | Canon imageRUNNER 2270 Copier
Canom MF 4200 shows paper jam, I removed the paper, but still shows jam
That's probably because the printer didn't recognize that the problem was solved (you removed the paper). Try powering off the printer and back on. That should solve the issue.
Mar 13, 2011 | Canon Office Equipment & Supplies
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam
Sep 23, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
23 people viewed this question
k24674
