Question about Scotsman Kitchen Appliances - Others
Where is the bin sensor on Scotsman CD1030MA ice maker located?
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
Posted on Jul 31, 2008
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: where are the bin full sensors located for
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Posted on Feb 09, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
Scotsman model 806 ice machine bin full ight is on and no ice in bin,replaced bin sensor a month ago i cant think of anything else it could be replaced the board last month to and the water inlet valve...
Is there anything hanging down in the beam of the sensors? check sensor connections at the controller make sure there is no moister in it and are making good connections. is your water real hard a lot of minerals dirtying up the eyes. if all of this is clear and sensors are good then nothing else but the control board.
Oct 02, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman ice machin model cme506AS-1F BIN FULL AND UNT OFF
Pull and clean bin full sensors or replace them then power unit back up.
Jun 26, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice machine keeps going to "off" mode. detects full harvest but no ice made. also condenser fan doesnt seem to be working.
o[en bin and look at your sensors, more then likely they have a scaley build up. the sensors are located below the ice maker and before the bin. It looks like a button of sorts one on each side, you can use a tooth brush to clean them. This should fix the problem
Jul 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme306as-1c bin full light on will not make ice.
Jan 30, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Kitchen Appliances - Others Logo
32 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
