Question about Dometic Refrigerators
Dometic rm 4207nd remove from location instructions
Need a manual for a Dometic RM 2610 refrig?
perhaps the RV dealer where you bought it can assist you
Feb 04, 2015 | Dometic Refrigerators
Dometic refrigerator troubleshooting rm 3662,
Hi, It is more then likely the heating element or a fuse in the electronic board located on the rear of the refrigerator. The heating element is located on the right hand side looking at the rear of the refrigerator. It is the probe like item that protrudes from the duct work with two black wires attached. You must disconnect the wires from the board then take the door off of the duct work, the the heating element will slide upwards to remove it. Please feel free to contact us 1-888-782-6665
ArctiCold Refrigeration We keep it cold
Aug 17, 2014 | Dometic Refrigerators
My 1987 dometic rm2600 works on electricity but not on gas. No light shows.
It is more then likely just a dirty orifice. The orifice is located just before the burner. It is a brass fitting that screws into the burner. It can be cleaned by removing it and soaking it in rubbing alcohol for a half hour then blowing it out. Do not poke anything through it! One cleaned try the fridge again, if this does not cure the problem then it is more then likely your thermostat that has failed. These thermostats are still available. They are a dometic dual stat and can more then likely be found on Ebay for around $100. For any other RV fridge issues please contact ArctiCold Refrigeration We keep it cold with locations accross North America we can help you with your RV fridge problems. ">
Aug 14, 2014 | Dometic Refrigerators
Dometic rm 2353
pull off back panel make sure 12 volts and check fusible links
Apr 11, 2014 | Dometic Refrigerators
Dometic 3 way fridge RM 2604
in back remove cover see heater line from board two black wires going to flu pipe remove and replace
Oct 21, 2012 | Dometic Refrigerators
RM 2804 model, does it have a fuse?
under black cover in back possible heater element
Jul 14, 2012 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
