Question about Garden
Can I get a replacement spring (4cm long plus hooks) for my tree loper ?
  • Garden Master
  • 16,746 Answers
Here you go, under 4 bucks.
https://www.theprunerwarehouse.com/corona-replacement-spring-6801-5.html
Tool Replacement Parts ' Rake Heads & Pole Saw Blades - Fiskars www2.fiskars.com > Gardening & Yard Care
Shop Fiskars gardening tool replacement parts! Keep all ... Power-Lever® Tree Pruner Replacement Head. $14.99 ... Replacement Rainwater Diverter (3" x 4").Replacement Parts - The Pruners Warehouse https://www.theprunerwarehouse.com/replacement-parts.html Find replacement pruner parts & tools parts for brands like Corona, Bahco, Felco & Silky. Shop our huge selection of gardening, pruning & harvesting tools!Corona Tools ' Replacement Parts ' Pruning Tools shop.coronatoolsusa.com/replacement-parts/pruning-tool.html Many parts appear interchangeable however only Corona parts will fit Corona tools. ... To locate the correct parts, start by typing in the model number of the finished tool in the SEARCH field located at the ... Best In Class · Long Handle Tools .... Grip - Aluminum Lopper Handles. $5.72. Add to Cart. Wish List Compare. Hook. replacement spring 4cm long plus hooks for tree lopper Google Search
Posted on Apr 25, 2017
    Top Expert:
  • Garden Master
  • 47,720 Answers
Sadly we here on FIXYA have no idea other than going to a hardware and seeing if they sell springs where you might obtain one for a loper
Posted on Apr 24, 2017
I have a circle of 4cm what is the diamiter?
What does the 4cm refer to?
If it's the diameter, then obviouly the diameter is 4cm.
If it's the radius, the diamter is 8cm.
If it's the circumference, the diamter is 4/pi cm.
Oct 18, 2016 | Office Equipment & Supplies
Tip
How to keep playstation 3 cool and silent
get 4 ridged foam pads dimensions 4cm by 4cm by 4cm (4cm cubed)
and place the foam pads underneath where the four rubber feet are while the console is horizontal
this will move the ps3 4cm in the air creating more room for the air intake vents on the left side (the side where the hard drive is)
since i have done this my ps3 has been silent while on cross media bar and i mean silent and barely noticeable while playing MW2
http://i813.photobucket.com/albums/zz53/fkuk/IMG_6156.jpg?t=1260908626
on Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Where does the throttle linkage spring attach on each end on a Yardworks 173cc 21" (Model# 11A-A2M7515)? I was mowing the lawn and pushing the mower close to a tree and a branch popped off the spring.
there is a little tab behind the air filter but facing forward. it is a funny shape. hook the spring end over this tab and you should be good to go
Jun 29, 2014 | Garden
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
2005 harley wide glide fork spring replacmet
Hi Anonymous, if it were only so, no you need to remove fender, caliper and wheel. Sorry
Feb 04, 2013 | Harley Davidson FXDWG Dyna Wide Glide...
I need a Singer Profinish "Thread Tree" replaced. Where can i order one?
Here is a link to a parts supplier.
http://www.sewingpartsonline.com/singer-14CG754-serger-machine-parts.aspx
The part you describe is:
4 Thread Holder, Universal #412519
$25 plus shipping
Feb 03, 2013 | Singer 14CG754 - ProFinish Serger
Replacement tension spring for telescopic tree prunner/loppers
Try a good hardware store for extension springs for the job. Take the broken one along as a sample.
Aug 21, 2012 | Hand Tools
HOW DO I DELEAT MUSIC
Hook up to your computer, right click the start button and chose explore, look at the bottom of the folder tree for your player, click the small plus sign out beside it, look for a folder named "music", click the small plus sign out next to it and see all your files there, high light and delete.
Feb 11, 2010 | Sony Walkman NWZA726 Digital Media Player
Replace rear leaf springs in a dodge ram 2500 '96
If you are planning to do this via shade tree like mysef, I have used a hydraulic floor jack on one end of the leaf spring touse the weight of the truck to depress the spring enough to pull the spring bolt out. It's a bit tricky... be very cautious if you do this.
Aug 31, 2009 | 1999 Dodge Ram
Need to know how to change the upper fork tubes and how much pressure is on the inner springs.
the preasure varries upon what springs you are useing progressive make a real nice set
however you should be able to hand load the springs
removeal is a little longer answer
support bike under the motor
remove front brake caliper and lines dont open the system or u will need to bleed it
remove the tire
remove the 2 large bolts on the top of triple tree
loosen the bolts on each side of lower triple tree
tubes should slide out of triple trees
drain oil from them
unscreww the top of tube carefull the spring is in there and it has preasure on it
turn upside down remove the lower screw oneach slider tube
you have to use the tube itsself as a slide hammer to remove it from the slider
now you are disasembled
Aug 29, 2009 | 1993 Harley Davidson FXR Super Glide
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
