Question about Ice Kitchen Appliances - Others
Machine drops ice once a B appears and machine stops working. What is the problem?
  • drivealot Apr 24, 2017
    Hi Austin Ofodile, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
SOURCE: Problems with Kenmore Side by Side Refrigerator
I had the same problem twice, and both times I had to replace the Solenoid/value part. I went through the troubleshooting guide for the ice maker, which was nicely tucked in the front kick panel, and everything worked fine. It went through the cycles but still no water comes out. I finally had to follow the trail back to the solenoid/value unit. Remove the connectors and plug an A/C volt meter into the wires which go to the solenoid, run the cycle, and if you have 120 volts AC, you should have water coming out of the fill unit (assuming the line is not frozen).
Here's the part I had to replace. again, twice in two years. Don't know if you have the same model, but good luck.
Posted on Dec 04, 2008
  • 1066 Answers
SOURCE: Ice maker stopped working
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Posted on Mar 31, 2009
  • 1236 Answers
SOURCE: Ice machine is only making flakey size ice.
sounds like there is a problem with the water in the sump escaping. Sometimes, the plastic grate under the evap plates break and pieces get stuck in the dump valve. It is a triangular piece that the pump attaches to via a hose. It is spring loaded and the pieces prevent it from seating, thus, water leaks into the drain that you will not notice. When the water level in the sump gets low enough, it goes into a harvest and drops small slivers of ice. I'd check that out first.
Hope this helps.
Posted on Feb 16, 2010
  • 1420 Answers
SOURCE: making ice but won't drop it, then the compressor
You can try and adjust your thickness a bit thicker. If this does not help, your hot gas bypass is not working and the evaporator is not warming. You will need a technician.
Posted on Apr 21, 2010
  • 4070 Answers
SOURCE: The ice machine stopped making ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Posted on Jun 26, 2010
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
Refrigerator is not making ice
hi rudy.many reasons for not making ice but first go through some basics.1-turn on ice machine/or leaver down 2-check water in ice tray 3-if empty fill manually .4-ice drops once and stops.then5-not filling with water. 6-check pipes and inlet valve.good luck ali
Jul 05, 2012 | KitchenAid KSRA25CNBT / KSRA25CNBL /...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
The machine is good , up and running but it does not stop till its over do i look for the stpping device for the machine once its full .??
the bin stat is either out of place or is not adjusted correctly. The machine should stop in no more than 10 seconds after the sensing bulb is submerged in ice. Make sure the bulb is mounted correctly and they come out of their holders on a regular basis.
Sep 30, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Making ice but won't drop it, then the compressor stops working.It is a Ice-o-machine
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Kitchen Appliances - Others Logo
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
mike cooper
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
