Question about Samsung Televison & Video
Television Panel SAMSUNG PS51F5500 BLAK LINES
Vertical lines
Was this problem why you changed the panel in the first place?
check your connectors and perhaps you have a bad Tcon.
Nov 30, 2013 | Samsung LN32C450 32 in TV
Ppm42m5 lines in picture
Horizontal lines = bad sustain buffer boards = replace buffer boards
Vertical lines = bad plasma panel = get used or get new
My request = don't kill the messenger :-)
Oct 08, 2012 | Samsung PPM42M5 42 in. HD-Ready Plasma...
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Mar 03, 2010 | Samsung LN-T4665F 46 in. LCD Television
I have a 46" samsung lcd television that will power up but only displays vertical lines in a variation of colors
Vertical colored lines usually means a bad panel. At the least it might be the t-conn pcb (a board connected to the panel). You might get lucky and just unplugging and replugging the LVDS cable (its a thin computer cable with lots of wires that goes from the main board (it has the audio and video plugs on it) to the t-conn board. You usually push in the clips on each side of the connector to release it. good luck! Panels cost more than the TV did.
Feb 23, 2010 | Samsung LN-T4665F 46 in. LCD Television
Colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Dec 01, 2009 | Samsung LNT4066F 40 in. LCD Television
Vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Sep 05, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Mar 21, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
