Question about Fisher Refrigerators
How to clear fault codes after repair on E522B Fisher & Paykel fridge
SOURCE: THE TOP PART (FRIDGE) IS NOT COOLING
We had the same problem. The duct between the freezer unit and fridge is probably iced over - a design problem apparently. Allowing to completely defrost will solve.
Posted on Aug 14, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
rylee_smith
  • 8619 Answers
SOURCE: fisher and paykel double drawer dishwasher flashes
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You’ll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
What does fisher paykel fault code f0 mean?
Faulty freezer temperature sensor - this would be for an older model fridge
Feb 23, 2016 | Fisher and Paykel Active Smart E522B...
What are the temperatures for fridge and freezer compartments on a fisher paykel E522B
Keep the refrigerator temperature at or below 40° F (4° C). The freezer temperature should be 0° F (-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Feb 21, 2015 | Fisher and Paykel Active Smart E522B...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
What is fault code 2 for Fisher & Paykel refrigerator model E522B?
The resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
Primary Action
- Check sensor connection at controller.
Secondary Action
- Replace sensor.
Jul 11, 2011 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Fault Code F24
fisher paykel fridge model e522b fridge section is freezing up
Mar 31, 2010 | Fisher and Paykel Active Smart E522B...
hello sir/mam
Sep 14, 2009 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
49 people viewed this question
Top Fisher Refrigerators Experts
John Tripp
John Tripp
Joseph Hoffmann
Brian Coughlan
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
