Question about Whirlpool Washing Machines
Whirlpool front loader washer, I have some black stuff coming out when I do a wash it drips on to the door
  • Official Brand Answer
  • 401 Answers
Marlene Kleinman, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Marlene Kleinman), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Posted on Apr 25, 2017
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
Slinteriors
  • 8617 Answers
SOURCE: Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Posted on Mar 27, 2008
  • 254 Answers
SOURCE: My front loader washer whirlpool codes fdu and the
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Posted on Apr 01, 2009
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
Front door leaks
The door gasket is bad this page will help http://www.appliance-repair-it.com/GE-front-loader-washer.html
I know the page says GE front loader but replacing the door gasket is the same.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Does your front load washer smell bad?
In order to keep all front loader washers from smelling and developing black mold make sure you leave the door open when not in use. If it is allowed to dry out between washings the smell and the mold will be squelched. You can also leave the dispenser door open also to dry out.
on Mar 12, 2012 | Whirlpool Washing Machines
My washer leeks from the bottom, slow drips,when in progress. Can I fix this myself
If you have a leaking FRONT LOADER, you will need to remove the lower toe panel under the door and inspect the washer interior cabinet to sufficiently determine where the source of the leak may be coming from. The following link explains how to access and inspect your washer for leaks:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of the cases with front loaders, the door bellow begins to leak. A routine inspection of the seal perimeter will tell you if there are any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Make sure you throughly check all drain hoses, hose connections, the pump seal and the dispenser hose(s) that penetrate the door bellow.
These problems can easily be repaired without the assistance of a repairman. If you have any questions, please post back and let me know. I hope this helps you.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool fron loader washer leaks at the door
The water should be able to come up to the door level without leaking. Chances are you have build up on the bottom side of the glass on your door. If so take a razor blade and scrape the build up off. Your door will quit leaking.
Aug 12, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Mar 27, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool duet front loader washer-leaks into washer when not in use
Yes, but if something gets into the valve it may prevent it from sealing correctly. Unfortunately these valves are all molded plastic around the seal, so there is no way to repair it. You'll have to replace the fill valve.
Jul 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De
