Question about Vacuums
My beaba babycook pro is turned on but unable to steam :( when i press the steam button it light on but nothing happened
5 Suggested Answers
SOURCE: McCulloch Steam Cleaner Problem
I have a similar problem but the light is not even coming on. This was a refurbished unit and the retailer sent a replacement so I can get into the broken one and see what's there.
Anyone have any ideas on how these work? Is it just off/on or are there saftey switches/fuses/breakers etc?
Posted on Sep 25, 2008
  • 29 Answers
SOURCE: My Steam Vac won't release any soap water mix
My model number Bissell is different than yours, but many models work similarly.
Capt. Obvious fixes: Water flow often stops unless both water and soap tanks have liquids. Also make sure the dial is set to Floor Cleaning, not Tool Cleaning or somewhere in between.
Sometimes an air pocket inside the machine (even a new one) keeps water from flowing, until you reprime the Bissell's internal pumps. To prime the pumps the easy way, turn it on, then press, hold, and release the water-and-soap trigger a few times, waiting a few seconds each time.
Still nothing? Prime it the slightly harder way. Separate the two water tank pieces. Only have the base tank filled and mounted on the Bissell without the piece that sits atop the tank. Turn it on. Kneeling on the floor in front of the Bissell, reach up and press the soap and water trigger at the top of the Bissell's handle and hold it in as if you wanted water to go through. On top of the water tank is a plastic grommet hole about 1 inch in diameter, through which you pour water to fill the tank. Seal that hole with the flat of your hand. You'll feel just a bit of suction. Lift your hand up and down a few times, a few seconds apart. Release the trigger and repeat a few times.
Still no liquids? If your Bissell has been used at least a few times, particularly if you didn't thoroughly clean the machine when finished, but after a year or so in a hard-water area like mine even if you are good about cleaning it, the water sprayers on your Bissell may have clogged with mineral deposits. This is a *fairly* easy thing to fix yourself, but please read all the way to the end and check out the GOTCHA before trying this.
Unplug the Bissell. Remove the water tank pieces from the top of the base. You'll probably reveal two red plastic pieces mounted in the Bissell's base, about .75" x .75". These spray water on your roller brushes when you press the water-and-soap trigger at the top of the Bissell's handle, and tend to clog with mineral deposits.
Only work on one sprayer at a time so you can see how it goes back together.
As you squeeze the red plastic sides of one red water sprayer, push up on the underside of the sprayer from underneath the bottom unit of the Bissell to release the sprayer from its mount in the base. Clean any lint or debris out of the mount area. Clean any gunk you can off the red water sprayer with an old toothbrush.
Now you need to remove one water sprayer from the hose. You need a pair of pliers. Use the pliers to squeeze the brass colored clip that is keeping the red water sprayed mounted to the end of the small hose there. Move the clip up the hose so it compresses the spring and is no longer on the red plastic water sprayer. (See GOTCHA about the spring, below.)
With the clip released, now you can twist and pull the red water sprayer out of the end of the hose. You'll need a little hand strength to do this. Just be careful not to break the water sprayer by using a tool. They're not particularly delicate, but breaking one would render your Bissell useless until it was replaced, so use a little care.
When you've removed a red water sprayer from the hose, put the end of the red water sprayer that was inside the hose in your mouth and seal your lips around it, and try blowing through it. If you can't blow air through it, it's clogged. Open up a paper clip and push it back-and-forth through the small hole in the hose end of the water sprayer back towards its middle. You'll probably push out a line of white mineral deposits. Clean them off the water sprayer with the old toothbrush, and try blowing through the water sprayer again. If air passes through clearly, you've fixed it. Push the water sprayer back on the end of the hose. Use the pliers to reposition the brass clip on the end of the hose over the water sprayer. Click the red water sprayer back into position in the base of the Bissell.
Now do the same for the other red water sprayer.
The GOTCHA: Once when I pulled one water sprayer off, the hose advanced up under the spring and I couldn't reattach the red water sprayer, because it couldn't reach the end of the hose. It’s best to use the brass clip or some other means (rubber band, tape, another clip) to keep the hose from crawling up inside the spring after you pull the red water sprayer off the hose. If the hose gets up under the spring anyway, despite your best efforts, fix this by removing the six screws on top of the Bissell base (this is the surface the water tank mounts on top of), and pry it up. Pull out the hose, reattach the red water sprayers on the hose, position the hose *very carefully* inside the base (there are mounts under there they need to fit into, so you don't break anything), push the red water sprayers through the mount holes and mount them, and then reattach the screws to the base.
You might want to prime the pumps again (instructions above). If the sprayers are clear, and the pumps are primed, but it still doesn't get the floor wet when it should, the problem may be more serious. You may a pump or motor inside the unit replaced.
As you probably have learned the hard way, as I did, it's VERY important to do a lot of cleaning of the Bissell after each use, more than the manual tells you to do. Clean the bottom of the unit. Thoroughly rinse out and empty both water tank pieces. Unscrew the three clear plastic pieces, one in front, two on the sides, that surround the brushes, and rinse them thoroughly in water. Clean off the brushes and all the lint and gunk around and above the brushes. (A water spray bottle and toothbrush are helpful here.) Tip the machine and get all the water out of the hole in the base. Release the red clip springs on the red water sprayers and blow on them. Doing this will slow the failure of the Bissell. It's a great little machine for the money, but it does have a learning curve and needs more pampering than a vacuum cleaner, doesn't it??
Posted on May 31, 2009
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
Hard water deposits. I ran some white vinegar through mine, like a coffee maker, and it worked for a while, but clogged again. So I unplugged it, let it cool and turned it over in the bathtub and squirted a small amount of Lime-Away into the hole where the steam comes out. Let it soak for 5- 10 minutes and it is working like is is brand new.
Posted on Oct 10, 2009
SOURCE: my euro pro s3300 shark steam cleaner heats up but
if you use it for more than an hour theres an automatic kill switch located on the inside designed to make you buy another one , but you can take it apart and hardwire it to bypass that kill switch , and your steamer will work once again.
Posted on Mar 03, 2011
Filled with water, pressed both buttons and nothing happening ??
Are you sure it's plugged in and if so, is it plugged into a live socket?
Nov 02, 2013 | Polti 3000 Vaporetto Eco Pro Steam Vapor...
When i plug in my shark pocket steam mop the light does not come on and nothing happens. plug works what can i do to fix this problem?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 04, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My sharp cleaner just quit steaming right in the middle of the floor. The green light is on but nothing is happening. Any suggestions?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Jan 15, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop stopped working......when pumping it nothing happens
heatman101
Nov 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark won't give off steam any more. I push down the handle and nothing happens. Then if I take of the head all the steams bursts out.
heatman101
Nov 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I plugged in the Shark Steam Cleaner; the green on light went on and it did not heat up. Nothing happened.
heatman101
Oct 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Plug in but does not heat up, no light on but
The thing just plain broke...
heatman101
Mar 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Machine will not work, i plug it in and press the power, but nothing happens.
I have the same problem with my shark. I dismantled it and found that a thermal fuse on the bottom of the tank is blown. I am trying to locate the part now. I will post when found.
Jun 10, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Steam shark model sc 505 uk
THE FILL CAP ON MY SC505 IS JAMMED. CAN NOT REMOVE THE CAP. WHAT ARE MY OPTIONS.
Aug 14, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
