Question about ViewSonic Office Equipment & Supplies
ViewSonic PJD5134 DLP projector shut down automatically
wellss123
  • 4 Answers
SOURCE: Viewsonic PJ513DB DLP Projector projects upside down
Double check which menu item you are expecting to find the orientation. It might even be under 'image', 'settings', or its own button not in the menu, Jon.
Posted on Feb 24, 2009
SOURCE: VIEW SONIC PROJECTOR IS NOT STARTING UP
Sounds like it needs a new bulb
Posted on May 05, 2009
SOURCE: my viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Posted on Aug 05, 2009
SOURCE: We have two Dell 2400mp DLP projectors that will
I just got done talking with Dell, they told me to unplug everything from the projector, power source and all. Then Press and hold the power button down for 45 seconds. This will disapate the electricity from the capacitors. Plug everything back in, and test. Seem to wook for me!! Good Luck
Posted on Mar 11, 2010
salt56
  • 373 Answers
SOURCE: I have a Viewsonic PJ558D
You need to reset the lamp timer. This is likely your problem since you changed the lamp.
Turn the projector on. open the menu. Go to advanced. Scroll down to the first option which should be auto source. Make sure this option is checked. While on this option press right once, left twice, right 3 times, then left 4 times. Another menu will appear. Scroll to lamp time and push enter. This will take it back to zero.
Posted on Jun 12, 2011
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
How do I open up?
NOPE U NEED TO REPLACE COLOR WHEEL
Oct 07, 2015 | ViewSonic PJD5134 DLP Projector
Viewsonic PJ558D shuts off after a few seconds
Sounds like the ballast board for the lamp stopped working.
Nov 19, 2014 | ViewSonic PJ558D DLP Projector
Viewsonic 5132 dust blobs
Most likely your DMD chip has dust or hair on it. You can try blowing it out with compressed air but the best thing is to tear down and clean the dmd chip itself. Very carefully. Here is a video of a similar unit. SO far all the DMD projectors I have worked on have had a very similar set up. Take pictures as you go.
MItsubishi XD206u DLP Projector Lens Assembly Cleaning
Mar 14, 2014 | ViewSonic PJD5132 SVGA 800x600 DLP...
My viewSonic PJD6241 Projector Model VS12476 DLP is not connected by power
1,is the power line is OK?
2,if the power line is ok, it means that the projector is defective
3,the mainboard or main power of the projector is defective?
Feb 09, 2014 | ViewSonic PJD6241 3D DLP Projector
PJD 5111 Viewsonic projector shuts down after 10minutes?
Hi! I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 20, 2011 | ViewSonic PJD5111 Projector
AMber light blinks as soon as I turn it on then shuts off
As soon as you turn it on hold down the menu button until the lamp turns on.
Oct 13, 2009 | ViewSonic PJ402D DLP Projector
Projector shut off
Your lamp may well have died..
Oct 07, 2009 | ViewSonic PJ402D DLP Projector
The projector would not shut down...it was not
if the lamp shuts off and the projector still runs, it's a cool down mode, and will shut off when it reaches a low enough temp. if the lamp doesn't shut off and none of the keys work, the keypad may be faulty. or locked. some projectors have a keypad lock feature that makes it so only the remote can be used. check your manual for keypad lock/unlock.
Aug 09, 2009 | ViewSonic PJ556D DLP Projector
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
292 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
