Question about Tablets & eReaders
What makes ipad to not ready a sim card? - Tablets & eReaders
How do I stop no SIM card coming up on my iPad screen all the time.
This is a bug in iOS 8, and there is no solution for it, but I did find 2 workarounds you can try.
1. Buy an empty SIM card and put it in it. Most companies will give you a free one.
2. This is more complex, and it is from a post I read.
I waited to update my iPad 2 but finally bit the bullet & did the update last week. Lo & behold, I started getting the 'no sim card' popup especially while using the App Store (updating & downloading new apps), settings, & apps that required location based services. I read through this thread & searched elsewhere for a solution. After turning off most location services & going through every app (I have many) the problem still remained. Airplane mode worked but I wanted to see if I could fix the problem. Prior to updsting to iOS 8.1.3 & had 'reset all settings' not erasing data. This morning I decided to do it again. still keeping my data. When my iPad rebooted I got the 'no sim card' message once (which is normal) but so far (fingers crossed) it has not reappeared. I also noticed that it rebooted with location services off which I then re-enabled leaving all the defaults on. I have opened maps, the App Store & settings, along with various other apps & my iPad is behaving nicely. It is also snappier than before especially safari. Maybe there were some cache files or corrupted files leftover from the last install. For anyone still having this problem, give it a try before totally resetting your iPad as new.
Feb 28, 2015 | Apple iPad 2 Wifi 16GB
How do i insert the sim card in an apple ipad 64gug
If your Ipad is a 3g enabled option then go to the follwing link for instructions: Remove the SIM card from your iPhone or iPad instead of removing it you just put it in.
Feb 23, 2015 | Apple iPad 64 GB 3G Tablet PC
What is the free imei unlock codes for a forgotten passcode?
There is no such thing as a free imei unlock code. If you need to unlock the sim in your iPad. (imei is connected to they Sim card) you can ask the provider to give you a new sim card with the same number. the new card has a new imei, new pin and new Puk.
Sep 09, 2014 | Apple iPad 2 Wifi 16GB
How to unlock ipad2 puk code
Your iPad 2 must have 3G, with a sim card. For the sim you need the pin and after 3 misses you need the puk. The puk is on the letter or card that came with the original sim card. On that letter is the pin and puk. sometimes you have to scratch away the metal layer.
If you want to unlock an iPad, with the lock code on, and forgot your pass code you have to enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPad, invoice, Prove of your identity (Passport) to the Apple store and hope they will unlock your iPad. With iOS7 Apple mede a very good security system. And while setting up the iPad and the security, you are warned several times what to do t make sure you and only you could enter the system.
Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Jul 09, 2014 | Tablets & eReaders
Where to put sim card on the ipad 3
http://www.ifixit.com/Guide/iPad+2+GSM+Headphone+Jack+%26+SIM+Slot+Replacement/6159
Follow Step 1 and 2 only.
Note: If you bought the wifi-only iPad then it won't have a sim card slot, if you bought the wifi + cellular version then it should have a sim card slot on the left-hand side towards the top
Apr 24, 2014 | Apple iPad 2 Wifi 16GB
Cannot connect to internet in supermarkets etc with ipad mini
I have not heard of supermarkets providing free WIFI. If you need internet access in places that dont offer it, you will need one of the following:
- A Mobile Hotspot (most modern phones can do this as an addon from the carrier approx $10 added to your bill)
- If you iPad is SIM card ready, you can buy a data plan for it (most models are not)
Hope this helps
Jan 30, 2014 | Tablets & eReaders
Ipad
If you purchased the 3G version,yes it will need SIM card.SLot is located on side of iPad.
Dec 26, 2011 | Apple iPad 32 GB 3G Tablet PC
How to unlock ipad w/ puk locked
Yes! It is possible to unlock iPad (or other iOS devices) now. And if you prefer an easier way to get the job done, see how you can achieve it on your PC or Mac on your own from this website: automaticiphoneunlocker.com
Mar 24, 2011 | Apple iPad 16 GB 3G Tablet PC
My sim card not installed
It may be a case of wrong cutting of the micro sim. Since the iPad uses a microsim, you haveto make sure that the sim card is cut perfectly. Do not use a pair of scissors, you have to cut it specifically using a micro sim cutter. Or you can check if the placement of the sim card is correct. Sometimes, the card seems to get loose thus making it unreadable by the iPad.
Mar 07, 2011 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
59 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
