How can I fix a KOLIN KFM-400F1J p11 error code aircon
4 Suggested Answers
  • 15935 Answers
SOURCE: I have an error code on Whirlpool washer.
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
  • 235 Answers
SOURCE: My kolin inverter type aircon wall mounted stopped working, the led display indicated E1. What does this mean?
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
Posted on Aug 09, 2016
  • 9947 Answers
SOURCE: Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Posted on Jan 28, 2018
Kolin error code E1 inverter 1hp wall mounted
What do you need to know, how to fix the error? If you need more questions for your AC Repair needs, check us out online.
Jul 12, 2017 | Inverter Heating & Cooling
E1 error code kolin inverter
Do want to know what the error means? Do you want to know how to fix it? If you need more questions for your Air Conditioning Repair needs, check us out online.
Kolin floor standing aircon error P10
What is the issue? - specifics needed for help.
Jun 23, 2016 | Heating & Cooling
My kolin 2.0 hp inverter series what does mean by E5 displayd code
Hi i am aircon tech, the problem of e5 is fan capacitor & relay connected the fan motor.
Jan 19, 2015 | Inverter Heating & Cooling
P7 error on screen
Try to Replace the sensor/ evaporator.
Aug 28, 2013 | Heating & Cooling
I have ac tcl model tac-42cf is not working and have error code in the display,how i can fix this trouble for this error?
I have the same problem..but i fixed that. if u have the same type with mine; TCL split type ac, TAC-42CF/A,380V 3N~. Then u can try this.
1. open indoor panel.
2. find 2 cable in socket pcb that is p11 And P12, u plug p12 on p11,and p11 on p12.
3. if not solved, try the same just like point 2 on power suply 3phase cable R.S.T try S to R, or else.
4. hopefully ur problem solved.
Aug 14, 2012 | Cars & Trucks
Kolin aircon manual
P4 -
what does it mean
Nov 14, 2011 | Heating & Cooling
Kolin window type aircon shuts off by itself
This may be due to the size of the room. The master bedroom may be smaller than the living room? The unit is therefore reaching setpoint temperature and cycling (shutting off)? Or it could also be a faulty thermostat.
Jan 23, 2009 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
