Question about Garden
I just got done mowing and shut the cub off. let it sit before putting it in the shed. I turned it on and it let out a pop. now its totally dead
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy;*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
Posted on May 12, 2009
SOURCE: 1872 cub cadet. Pto keeps turning off. Will mow a
Check your battery posts and terminals, they may be corroded, or your battery may be dying.
Posted on Jul 23, 2010
  • 22306 Answers
SOURCE: 2007 Cub Cadet LT1050 ~ 180
Sorry but for some reason the clutch is worn out ,maybe grass too long who knows but you will need to replace the the shoes on the centrifugal clutch ,when its cold they grip but once they warm up they slip just like a car clutch
Posted on Sep 03, 2010
  • 1035 Answers
SOURCE: i have a lt1045 cub
Hi. This is a common problem for this mower. Remove / unhooked the safety on the seat then problem will be resolved. Have a good one!
Posted on Sep 06, 2010
  • 6468 Answers
SOURCE: my cub cadet 1042 stalls when mowing up steep incline, what's the problem?
check the float level in the carb
Posted on Apr 06, 2012
After mowing with my cub cadet model 13WQA1CQ009, I see streaks of dead grass. No puddling when it's sitting still. I'm thinking it's a gas leak. Can you tell me what to check?
with the engine off look and smell for a fuel leak if it is leaking fix it.
if it is leaking you should have noticed an unusual fuel consumption.
Jun 20, 2017 | Cub Cadet Garden
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
Mower blades will not engage when hot
overheating safetybsprings are wore out. they either got over heated or reached their limits
Jul 24, 2014 | Cub Cadet Garden
Cub cadet zero battery is dead after sitting a few days.
This is an electrical issue, you have a short in the harness, can very well be the keyswitch...even though you turned it to the off position, it's giving the unit the impression that it's still in the on position.
Jun 02, 2014 | Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Mower LT 1046 have to jump, but won't stay running
Check the bottom of the carburetor for a little solenoid. If it has one, the battery may be dead enough that it can't keep the solenoid open causing the carb to shut off the fuel flow causing the unit to die. The easiest way to check if it works is by turning the key to the run position and listen and/or feel for the solenoid to click. If it clicks it is working and there is another problem, if it doesn't then replace it. I recommend having the battery tested or replaced too
Jan 03, 2013 | Garden
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Our cub cadet will run and mow for a short time then it shuts down and won't start if we let it set for awhile then it starts it done this about 4 times now it acts as if it needs the battery char
Take your battery to Oreilly's or autozone,, ask them to check the CCA (Cold Cranking Amps).. this is the true measure of battery quality... if its low, they will tell you and get a new one... see if it runs better,,, it not... you may need the assistance of a qualified professional.. ( may be a coil)..
Aug 10, 2017 | Cub Cadet Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
