Question about Whirlpool Duet GHW9150P Front Load Washer
Washer makes such a loud noise when it spins and moves
When the washer spins the noise lever is so bad I can hear it upstairs. It is located in the basement and it has done this from the date of purchase on 7/14/2008. It also vibriates so bad we have to push in back in place. We have had it checked by the service man several times and it still does this. All they keep saying is that it shouldn't do this. I want to put it up stairs but will never be able to. I would not recommend this this machine to anyone.
    Sniper:
  • 57 Answers
Hi, From what you describe, this is a problem I have seen before.
This machine has a bad bearing in the transmission and will soon fail completely.
This is usually cause by it being improperly installed and not setting level, which causes it to be unbalanced, jump around with bad vibration.
Being used this way has damaged it, which is the loud noise you are hearing.
Posted on Jul 25, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Washer makes a loud noise on spin cycle
Alright, well, thats when you open the lid, move the clothes around close the lid and walll la. okay having more problems, well get a new washer.
Jul 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
My washer does not spin and makes loud noise
Hi!!! You have a bad motor coupler replace and you should be fine..
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool awm8121 - spin cycle high pitch sound/scretch
Front loaders are great for savings on water and electricity. Most of these machines only use about 5 to 7 gallons (US) of water and spin with a velocity anywhere between 1300 to 1800 rpms. This also saves on dry times because your clothes are virtually spun dry. Why am I telling you all this? People buy them with good intentions, but the common complaint I hear is that they are noisy. It is this spin velocity that contributes to that noise. You need to make sure that the foundation under the washer is stable. If your washer is located in a mobile home, upstairs laundry room, home with a crawl space, etc., sometimes these floors have a tendency to flex as the washer spins. If the floor flexes (even a little) the washer will vibrate and make noise. An easy fix to help redistribute to weight of the washer is to place a sheet of thick (at least 3/4" in the US) plywood under the washer to help reinforce the floor. This must be screwed down or affixed in such a way that it does not move. This will take care of any vibrating issues. Now, if your problem is strictly with noise from the machine, some of that is normal I'm afraid to say. However, if it sounds REALLY loud (like a rumble) this is a symptom of a rear bearing that is going bad. If that is the case, the entire back shell of the wash tub has to be replaced in order to replace the bearing as they are molded into the plastic. This can be an expensive repair job if you decide to pursue this option. Let me know if any of this helps. Kinda hard for me to diagnose without being there to hear it.
Jun 24, 2007 | Whirlpool AWM6120 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
305 people viewed this question
Dan Webster
Dan Webster
Sal De
