WHAT IS A GREEN CARD USED FOR - Computers & Internet
I got a new green dot card and can't remembered what address I used
Hello, You will have to call the green dot cust service number on the back of the card, for help with that.
May 28, 2014 | Computers & Internet
Card error light flashing green
When the camera accesses the memory(card) a green LED will burn or flash. When it can't do what it wants, it will warn you.
A memory error, can be caused by lots of things. Like card full, card physically damaged, file system damaged. Too many folders, too many pictures. Wrong card (SD, SDHC or SDXC) cannot be used in every camera.
Check if you did put in the card correct (not the wrong way around) Check if all contacts on the memory card are clean, shiny and straight. Check if you did not switch the lock switch to the wrong position. Check if there are still pictures on the card, in an external memory card reader. put all the pictures you can find on the computer and than try to format the card. (in the computer, FAT 32) but after you put it in the camera. do a format in the camera too.
Success
Mar 05, 2014 | Samsung L200 Digital Camera
How do you attach the speaker system on a dell dimension c521.
The green port on the back of your computer is for small speakers, this is the one mostly used. If you have subwoofer connect it to the orange port. The black port is used if you have surround speakers. The white port is for side surround speaker.
This is the integrated or built in sound card. If you have add on sound card then you need to use that instead. You can get the manual of your computer by clicking on this link.
Jul 25, 2011 | Dell Dimension C521 PC Desktop
My mother board is Intel D945 GCL. after installing windows 7 there are some problems with my sound..
Hello
Windows 7 does not support open al audio.If you have onboard sound download and install the drivers from intel.
If you have a sound card like a soundblaster or saphfirre go to the munufacture website and download and install lateest drivers for win7.
Verify your win7 is 32 or 64 bit in system settings in control panel.
Mar 28, 2011 | Computers & Internet
I have a Samsung CT5038VC CRT TV, it was showing very well , then suddenly, the entire screen went green! you can still see, but everything is green. Please assist me in finding the solution to this...
Hello
Since picture is there, sound also mut be. The screen colour went green is your complaint. It is due to the video output stage of your TV. The fault mainly occur in the picture tube base board card. Loose or bad solderings ara always noted. There are three video output trnsistors there in the base board In some models of Samsung sets, either three individual Ics or one single Ic is used. Anyway the fault lies around this card.
You jsut open your TV, pull out the base card from the picture tube neck, care must be taken when you do, not to shake sideways or up down. Just pull it straight back, otherwise picture tube base pins or picture tube neck wiil get damaged. Before doing this check the vlotages of the three cathode pins of picture tube base. It can be done withoug detaching it out from the neck. There are three cathodes. Blue, Green and Red. In most Tvs these voltage will come near to 130 vdc or so. In your TVs case, now the green cathode voltage will be low with respect to the other two cathodes.
This may be due to a loose soldering or fault related to green cathode itsef. If transistors are used, check the green output transistors collector voltage,and compare it with the other two voltages. If Ics are used, do the same. If one Ic is used the checkings are the same.
Just resolder all the loose suspected points before replacing anything first. If it does't help, you just desolder out the green bias drive, whether it is a transitor, or Ic, whatever may be. If it is transitor, just plug it to the picturetube and switch it on without the green drive. Now you must see a different colour, a mingle of red and blue, a type of cyan. If so you can make sure that green output, whatever type it may be, is faulty. Just replace it with same type and number. Check the 2W resistors, if any used, for open, especially to the green drive transistor load resistor. Ok.
Nov 13, 2010 | Samsung Televison & Video
Do sound cards wear out? I can see the three places blue, green and red in the back...behind them (inside) is a small mettle box....Is this a sound card? How do I check to see if there is a driver? and...
any piece of electronics is subject to wear and tear, but they usually last a long time. the blue green and red?(usually pink) are your sound card if they are circlular. blue is an input (usually not used). green is output (used for general speakers or headphones) and pink (red?) is microphone. first things first...plug some speakers in to the green port, turn them on and play a song and see if anything comes out.
check your device manager "right click my computer, properties, hardware, device manager" and look for any icons with a yellow question mark or exclamation mark" if you dont see any, your drivers are installed..if you see some with those markings, write them down here and i will help furthur.
Apr 26, 2009 | Dell (8H390) Sound Card
Install Used ATI 7000 graphics card on Dell Optiplex GX270
OK, I got into Dell. Your motherboard should support an AGP card.
GX270 System Boards
Is there something in the green slot?
That is the AGP slot. If there is something in it, remove it. The ATI card should work in it if it is an AGP card.
Feb 12, 2009 | ATI RADEON 7000 PCI Graphic Card
Card is green, wireless router is green , but no internet
r u c'in any message as limited r no connectivity in wireless connection,did u chk if u r able to go online wth the cable connection in ur laptop
Nov 05, 2008 | Dynex 802.11g Wireless-G Laptop Card
Problem
If D70, and it applies to any card used then examine the loading LED. This is a green diode which gives a brief flash when you insert a card. If it continues flashing whilst giving you the message, then this is a know fault with the camera and Nikon will fix it free of charge.
Apr 01, 2008 | Nikon D70s Digital Camera
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
