HAVE A MATAG 5000 SERIES WITH STEAM PUT IT IN CLEAN WASHER CYCLE STARTED COUNTING DOWN MIN WASHERS DOING NOTHING GOT TO 1 MIN AND IT STOPPED HIT CANCEL INT CAME UP IT WONT GO INTO ANY OTHER CYCLES
2 Suggested Answers
chop71014
  • 124 Answers
SOURCE: have matag washer 5000 series w/steam SET IT TO CLEAN CYCLE display showed time started counting down washer didnt respond i hit cancel and INT showed up in display dont know how to erase it
INT means interrupt I believe.
Just press 'play' again
Posted on Apr 17, 2017
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
LD ERROR CODE AND WONT DRAIN LID WILL LOCK
try any button sequences yet . try holding start button and a cycle button hold both down to reset
Apr 01, 2013 | Whirlpool Cabrio WTW6800W Washer
KENMORE ELITE WITH CATALYST FILLED WITH WATER AND WILL NOT DRAIN AND SPIN
REPLACE THE DOOR SWITCH . IF THAT DOES NOT WORK REPLACE OR CLEAN THE DRAIN PUMP..
Apr 25, 2017 | Kenmore Washing Machines
Ge Washer GSLP1100D0WW keep getting a dr code near the end of the cycle it stops at 28 mins and then when i hit start it counts at 30 gets down to 28 again and does the same dr code again
Your problem lies in the PCB assembly, or pump motor, most likely the PCB assembly.
1. open lid
2. remove control panel screw covers & screws
3.lift control panel
4. remove screws connecting PCB assembly to control panel
5. Remove PCB from control panel by pushing PCB from right to left.
6. Disconnect wire harness connectors from PCB.
Hope this helps!
Jan 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
