Question about Dishwashers
Hiya my Teka dw6 59 f1 dishwasher has water left in at the bottom and also the programme button isn't working properly. Any idea why?/help?
  • 487 Answers
SOURCE: My teka dishwasher does not
Means that your pump is obstructed. Clean the filters out and if tha does not work clean your pump and drainhose.
That will solve your problem
Posted on May 01, 2008
  • 1239 Answers
SOURCE: Teka Dishwasher DW6 59 FI
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
  • 1075 Answers
SOURCE: My dishwasher is draining properly.
yes there is cleaners.Check filters at bottom of machine fiirst,then buy an cleaner.adrian,,,,
Posted on Jul 15, 2010
  • 3247 Answers
SOURCE: Teka DW6 59 F1 Lights 4&5
I am slightly unclear if lights 4 & 5 are counted left to right or right to left when facing the dishwasher.
If you are counting right to left - then lights 4 & 5 flashing implies E3 fault - heater failing to heat.
am suspecting the heater unit is failing. Try to run dishwasher on a colder program like DELICATE and see if goes through.
If the flashing does not go away by turning power off and back on then the heater or the thermostat has failed and will need replacement.
Hope this helps fix the problem. Please post a comment if this is not helpful.
Posted on Mar 17, 2011
SOURCE: need an english manual for
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Posted on Mar 30, 2011
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
How do I fix a Teka DW6-59 dishwasher thermostat problem
If it heats and fills, would not think thermostat, tstat checks that the temp is ok, then prog moves on, If tstat, would never move on. think more after that, maybe, does the pump work, could be broken wire power to pump, can you hear the pump working, if continuois cycle, at what point does it stop and start at beginning, does it pump water out? if not water level sensor.
Jul 29, 2014 | Dishwashers
Meiko dishwasher. Do I have an eeprom problem?
sounds like it could be a defective cylinoid switch...this will not allow water to flow properly through the machine....this is located at the water connection....try replacing and reconnect water...good luck
May 19, 2014 | Meiko Dishwashers
Need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Programme won't finish and dirty water doesn't drain out ...
If you have a warranty on the dishwasher, I would call them to fix it>
Jul 06, 2017 | Belling 24 in. IDW603 Built-in Dishwasher
F1 code on Fisher and Paykel dishdrawer
It would seem to be in an endless loop (firmware glitch). Initially, pls try:
  • unplug from the mains or switch off the breakers for a couple of minutes;
  • plug back in/switch on the breakers say after 20 minutes;
  • press POWER to turn drawer on;
  • Press and hold (at the same time) both the POWER and ECO buttons for a few seconds;
  • a five minute demonstration wash cycle will come on;
  • press POWER again to put unit on standby, all the LCD segments will start flashing (and light up);
  • press and hold START/PAUSE for a few seconds to hear confirmation beep/tune.
Alternately, should you have the two-drawer, open any drawer and look at the wash intensity/economy buttons. Now press them, one at a time, alternating between the two, at even timing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 15, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
My teka dishwasher does not drain properly and there is water left in the bottom after the cycle has finished
May 01, 2008 | Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Prgramme not starting or finishing
The "mushroom" bottom is just a lever that operate a switch. It seems that a part of the switch's mechanism is broken or release.
Jul 22, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
Top Dishwashers Experts
