Question about Exercise & Fitness
BodyMax E60 Elliptical Cross trainer-it made a loud clunk noise when I was using it this morning.It feels like the chain has come off(like when you are on a bike).Does this happen and can it be fixed?
maxtreadmill
  • 832 Answers
SOURCE: tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Posted on Apr 11, 2010
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Posted on Jan 16, 2011
  • 356 Answers
SOURCE: Does Life fitness have an
Here is the operations manual:http://www.lftechsupport.com/c/document_library/get_file?p_l_id=27605&folderId=122335&name=DLFE-16196.pdf
You can find other guides from Life Fitness at their manual search site: https://www.lftechsupport.com/web/guest/user-documents
Hope this was helpful. If this wasn't what you were specifically looking for, please leave a comment explaining what you needed, thanks.
Posted on Apr 21, 2011
mastermaid
  • 502 Answers
SOURCE: Manual for Trimline E418 elliptical cross trainer
Get the manual here
Posted on Aug 10, 2011
ercupa190
  • 12223 Answers
SOURCE: marcy cyclone elliptical cross trainer intrution
Dear Sir:
Please go tto the 2 next web page:
1) this is Free download: http://fitness.manualsonline.com
2) In this web page you must pay: www.fitnessrepairparts.com
Sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 31, 2011
User manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Oct 28, 2014 | Exercise & Fitness
Precor EFX 546 Version 1 making clunking noise
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Life Fitness 9100 Elliptical Squeaks
You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Nov 10, 2012 | Schwinn 430 Elliptical Trainer
What is an elliptical trainer?
An elliptical trainer is a stationary machine used to stimulate the action of running, stair climbing, or walking. It puts barely any pressure on your joints giving you a great non-impact cardio workout that can vary in intensity levels.
Aug 02, 2012 | Exercise & Fitness
An elliptical trainer or cross-trainer is a stationaryexercise machine used to simulate stair climbing, walking, or running withoutcausing excessive pressure to the knees.
Jul 09, 2012 | Exercise & Fitness
My elliptical makes a grinding noise when revolving
Inspect the ramp that the wheels travel on. If its pocked up or worn then it will cause the unit to feel like its grinding when in use.
Sep 06, 2010 | Precor EFX 546i Elliptical Version 4
When turned on makes clunking noise. I am able to use the machine when not pluged in. when the electrical display is on makes clunking noise
You may have to disassemble the unit remove the side panels if the foot pedal assembly, arm assembly bearing and bushing are in good shape. You'll have to inspect the flywheel and pulley assembly with the power on & off . It will be a process no doubt.
Jun 13, 2010 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
