Question about The Office Equipment & Supplies
Induction cooktop both left hand hot plates will not engage with the cookware that has been used for the last 18 months just keeps clicking as if the magnets wont hold to the pots
Indesit vix644, 18 months old, right hand hot plates work perfectly, have turned off power at the mains for several minutes to reset , no joy
SOURCE: Electrolux Induction Cooktop: My husband
Power down, then back up. You will be lucky if that fixes it though. I had the same problem here. It is in-warranty so I called Electrolux. Parts came in only after requesting them multiple times. Repairman put them in and they were bad. After a month it is still broken. I was promised a new unit, but little real action. Electrolux is a horror. No way to DIY this thing, too complicated. Cut your losses and buy another brand.
Posted on Aug 11, 2008
SOURCE: TV does not turn on anymore...
yh i no ur mum can fix it
Posted on Oct 12, 2008
Zerr0
SOURCE: ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Posted on Nov 25, 2008
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 3315 Answers
SOURCE: My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Posted on Jan 16, 2010
All 4 rings get extremely hot immediately and don't cool down.
Appliance Science: The hot physics of induction cooktops ...
www.cnet.com > Appliances
CNETJan 12, 2015 - Induction cooktops don't heat up themselves: they create heat in the base of the cookware. ... the cookware, and so react quicker when you turn the dial up or down. ... US consumers don't like them because they grew up on gas rings. ...pans, they don't get hot when you put them on an induction cooktop.
4 Lessons I Learned From My Electric Stove - Life in the ...
www.thekitchn.com/why-im-grateful-fo...
Apartment Therapy's The KitchnFeb 24, 2015 - Electric stoves don't have a lot of redeeming qualities. ... "low" burners rather than wait for the front burner to sufficiently cool down. ... burner for all my cooking, as I did when I cooked on a gas stove. ..... I was used to looking at the size of the flame to gauge how hot it really was, I never looked at the dials.
Moving From Gas to an Electric Stove: What I've Learned So ...
How to Fix Problems With Burners on an Electric Stove ...homeguides.sfgate.com > Landlords & Tenants > Landlord ProblemsElectric stoves rely on electrical resistance to heat up the burners on the cooktop, which means they function much in the same way as electric heaters. ... When one of the burners stops working, you can usually trace the problem to the burner switch, theburner receptacle or the ...Electric Range Stove Repair: How To Repair Burner ...? 6:52https://www.youtube.com/watch?v=ndQU7RtqfRwJan 31, 2012 - Uploaded by applianceassistantHow to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... How To Test Stove ...Fixing Electric Stove Burners that Don't Heat Up Properly ...? 2:34https://www.youtube.com/watch?v=GfqaPcha__o
Dec 15, 2015 | Kitchen Ranges
MY INDUCTION COOKTOP IS NOT WORKING PROPERLY
Are you using the right cookware?
Mar 27, 2015 | Cooktops
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
Mar 15, 2015 | Eurodib Induction Cooker
Hotpoint induction hob wont turn on
Check power supply at socket or meter box. Make sure that the circuit breaker hasn't tripped. Also, induction cooktops wont heat without induction cookware. They must be steel. Glass cookware wont work on an induction cooktop.
Jan 03, 2015 | Cooktops
Q1 1210-017-199
An E1 reading typically means that your PIC does not detect
cookware on its surface. This can occur for one of two
reasons.
1. Have you placed a pot or pan on the unit? The induction
coils contained within the PIC will only work when they are
in direct contact with a piece of cookware. To maintain your
appliance's effectiveness, always ensure that it rests on a flat
surface and that contact is consistent with your cookware.
Refer manual at this sitehttp://www.nuwavepic.com/resource/pdf/NuWave_PIC_Manual_and_Cookbook.pdf
May 29, 2014 | Hearthware NuWave Precision Induction...
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Induction cooker
follow this instruction .God bless you
  1. E0 Error
    • 1
      Put a pan on the cooktop surface if you receive an E0 error. This error indicates the absence of cookware on the ceramic surface.
    • 2
      Remove your cookware if you are still receiving an error.
    • Sponsored Links
    • 3
      Hold a magnet next to your cookware. If the magnet sticks to the cookware, it is appropriate to use with an induction cooktop.
    • 4
      Place the cookware back on the cooktop if the magnet sticks, or replace it with appropriate cookware if the magnet does not stick.
    E1 Error
    • 5
      Turn off the cooktop.
    • 6
      Remove the cookware from the cooktop.
    • 7
      Unblock any external ventilation slots.
    • 8
      Let the cooktop cool down for at least 10 minutes.
    • 9
      Place the cookware back on the cooktop and turn it on again.
    E2 Error
    • 10
      Check to see if there is any food in the pan.
    • 11
      Place food in the pan if there isn't any in it.
    • 12
      Turn the cooktop off if the error does not disappear and let it cool down for at least 10 minutes.
    • 13
      Resume cooking by placing the cookware back on the cooktop and turning it on again.
    E3 Error
    • 14
    • 15
      Check your house's fuse box for blown fuses, tripped circuit breakers or voltage fluctuations. Replace any blown fuses and reset the tripped circuit breakers if necessary.
    • 16
    • 17
      Turn the cooktop back on and resume cooking.
Read more: http://www.ehow.com/how_7492378_troubleshoot-summit-induction-cooktop.html#ixzz2Ze1uo0as
Jul 20, 2013 | Heating & Cooling
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
24 people viewed this question
Top The Office Equipment & Supplies Experts
Jerry Greenberg
Jerry Greenberg
old marine
old marine
Mitch Vass
Mitch Vass
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
