Question about Refrigerators
I have a SRS20DTD side side refrigerator. The Freezer section has stopped working and the refrigerator section is working at 15C an above. What can be the usual problems with this kind of situation.
I have removed the sensor from the Freezer but still the fridge is working at 15C. Dont know how the sensor is connected to this problem.
  • Julian Pearson Apr 24, 2017
    Sorry, that was my only suggestion as far as DIY fix is concerned.. though coolant leakage might be a cause.. n ot something the average Jo can resove
    New Friend:
  • 28 Answers
CVhances are it's very simple.. and the tell tale sign is a warmness to the front of the appliance where the two doors meet.
pull out the appliance and check next to the compressor, which will have a bit of ciopper pipe comping off it, with the end crimped up... it will also have a fan, like you get in a PC.. chances are that a wire or other obstruction (like a rodent or accumulated debris, is preventing that fan from turning.. free it up, hold back and wires with some cable ties to stop it happening again, and it should return to normal temperature within a few hours.
Posted on Apr 24, 2017
Testimonial: "The fan is working properly no problem. I have already checked it out. What next can be done."
Neff K3965 side-by-side American: Freezer works but Fridge doesn't any more, 3 days after defrost
Can you remove the freezer rear panel again and take some photos of the frost pattern so I may see what is stopping the cold airflow to the fresh food section?I'm here on Fixya if you have questions
Contact Me Here
Appliance 911 Sea Breeze
Nov 23, 2015 | Neff Refrigerators
Sr s22ftgrs bad freezer temp
HI PAVLOS.from what u say it sounds like it just needs a good good service.clean all vent holes and blow the hell out of the condenser unit .it should work.ventilate well.could be heating up and stopping long.good luck ali
Jul 12, 2012 | Samsung SRS20DTD Side by Side Refrigerator
Hi I have pressed the vacation button on my side by side refrigerator/freezer as we are going away for 8 weeks. The display has lit up but there is no difference in the way the fridge is operating - same...
The settings will reset to a lower settting as the fridge/freezer will not be disturbed . So wait for the fridge to run and shut down and it will continue to run in this low mode to save power but to keep the food in prime condition. The fridge alone will not be shut down.
Aug 31, 2011 | Samsung SRS20DTD Side by Side Refrigerator
Just bought upright freezer and it wont get cold plugged in for 12 hours
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Apr 22, 2011 | Samsung SRS20DTD Side by Side Refrigerator
MF-183 Brada Freezer
Having this same problem! cannot get past the front alert light... were you able to fix it?
Jun 27, 2010 | Samsung SRS20DTD Side by Side Refrigerator
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
